Bad O2 Sensors causing 92 SC to have NO real power?
Old 06-18-12, 01:56 PM
ChrisH
ChrisH's Avatar
Default Bad O2 Sensors causing 92 SC to have NO real power?
So I went to the dealership today and had my car scanned. They said that the culprit to my issue is the O2 sensors. My car got a lean run code(25). What I would like to know before I dump another couple hundred into this car, is that would bad o2 sensors cause a car to not go full throttle? I feel the throttle open up fully when I floor it, but the car only creeps. Heres a list of things I have done to date
Oil Change
Transmission oil/Filter
Shift solenoids
Both Ignition coil packs
Spark plugs
Fuel Filter
Must have swapped the tps and maf sensor about 5 times already....but unsure if they were broken.
Any assistance would be greatly appreciated!
Btw, mass airflow sensor unplugged causes car to almost stall out when i push the throttle, W T F.
Old 06-18-12, 03:31 PM
GS4_Fiend
GS4_Fiend's Avatar
Find a mechanic that has a lab scope. He can determine if the o2 sensors are bad by adding propane, snap test and observing the readings
Old 06-18-12, 07:16 PM
ChrisH
ChrisH's Avatar
Now how much would that cost? I priced the new sensors at 40 bucks a peiced plus s/h. I'm so close to just going with a manual swap, this issue is crazy! Its like driving a car with civic acceleration!
Old 06-19-12, 05:19 PM
ChrisH
ChrisH's Avatar
Update , the throttle cable seems to be seized? When it was raining yesterday, the car was driving perfectly? My question is, would the throttle cable being seized cause the car to not drive properly in D but ok in L? Also noticed my main seal is leaking.
Also my OD light is still flashing, is it possible for it to be a solenoid other than the shift solenoids ? Any help is appreciated!
Old 06-19-12, 05:29 PM
rogers2014
rogers2014's Avatar
Hey Chris, ok, if that is so it would make sence for the O/D to be flashing as it can't go into the 4th gear, remember the whole purpose of the cable is to shift from gear to gear and lets take for instance if it is siezed that means when you shift it into drive and the O/D is on it's stretching the "siezed" cable even more hence it catches, sometimes it doesn't. SO it would make sence the car doesn't drive properly in D but in L. It seems to me that it is the cable, i had a tranny cable problem with a toyota matrix it got real stiff till the point of snapping. So i know,
excaliber
12-13-14 07:51 PM
worldforgo
03-23-11 08:22 AM
jcorredor
RX - 1st Gen (1999-2003)
21
07-14-08 11:08 AM
ARISTOFIED
02-05-08 02:45 PM
chrisalpho
01-26-07 08:42 AM
Quick Reply: Bad O2 Sensors causing 92 SC to have NO real power?
