What would make my shifter shake?
Old May 29, 2012 | 08:40 AM
OBEY414's Avatar
OBEY414
Default What would make my shifter shake?
On the freeway I was going 60+ and my shifter started to shake.
Trans mount?
Warped rotors?
Old May 29, 2012 | 08:54 AM
93MSB's Avatar
93MSB
if its during braking then its rotors
if not check the trans mount first, i would also look at the engine mounts if the trans mount looks good
if you notice the steering wheel shaking too then you might want to look at the steering rack bushings (mine first started shaking at 60mph when they were failing)
Old May 29, 2012 | 09:16 AM
sj408's Avatar
sj408
Actually if i remember correct there is a rubber connector piece, somewhat of a bushing somewhere on the driveline that causes the shifter shake when it starts to go, let me see if i can dig up the old threads of people fixing it.
https://www.clublexus.com/forums/per...aft-bolts.html
20 seconds o searching proved useful there it is
Old May 29, 2012 | 09:22 AM
OBEY414's Avatar
OBEY414
That would be helpful sj408
I recently replaced my driveshaft support bearing hoping it would go away
Old May 29, 2012 | 10:26 AM
OBEY414's Avatar
OBEY414
I callee the Lexus dealership and told them I needed a flex coupler. They had no idea what I was talking about.
Does anyone know the correct name of the part? Or Atleast what it does?
Old May 29, 2012 | 06:36 PM
sj408's Avatar
sj408
bring them a picture, ive come to realize 90% of the guys who work at the lexus dealership dont know ****. Like when they told me they needed 6k to return my car back to stock to diagnose what ended up being a faulty TPS..... (my car only has an intake on the engine)
Old May 29, 2012 | 07:28 PM
Vwpride12's Avatar
Vwpride12
Drive shaft isolator
986ci's
Feb 29, 2012 06:53 AM
durtysc300
Aug 12, 2011 05:34 PM
1gs430
Nov 3, 2005 09:09 AM
shmelvin
RX - 1st Gen (1999-2003)
Dec 27, 2002 06:49 AM
