350Z trans adapter?
I got the clutch and pressure plate today
looking up the part numbers, it seems to be an OEM Aisin 3SGTE pressure plate painted blue and a FX/F1/XTD ebay clutch, REALLY havnt heard much good about these.
I hope gripforce will warranty these parts, I wish I could trade it in for a credit towards Exedy or ACT, but as long as this holds up no problem
and I guess the reason it took so long for the clutch parts is because it comes from another retailer, gripforce. so I guess its on them for the delay.
Ordered and paid in full on January 31st got the final parts today, most came around the one month mark.
I guess this is all pretty good for custom order parts no?
With the collins adapter to the 1UZ the KA/350z trans bolts right up. No machining necessary.
I used the KA trans. The only things I had to do was grind down the starter bolts, and cut off the starter hump on the bell housing of the KA trans. The starter hump on the bell housing gets in the way and is a pain to get it in the car. Oh, and you have to "knife" the starter gear also. This just assures the starter gear will align properly with the flywheel. Everything else is bolt on.
ive been hearing about "kniving" the starter gear. I dont get it, what does it mean to do this?
also I hate how this thread has died and I am in the middle of this swap.
"You should 'knife' the 1UZ starter gear by shaving one side of the tooth down. so when the starter plunges out to engage with the flywheel it doesn't hit the face of the flywheel and slips right past it, the proper side to shave down is the opposite side of which side that has wear marks on it." [sic]
this doesnt make sense to me, is the gear on the custom flywheel not the right size? I dont see how it would slip past it.
also I dont feel a grinder is going to work for such a thing, dremel? file?
I asked a wrecker to measure the shifter placement of a Frontier 6-speed and he advised the center of the shifter is located 26" behind the bell housing. I'm guessing the Collins adapter is at least an inch and a half thick. Seems like it would need a simple swan-neck shifter to line up perfectly in the SC/MKIV.
yeah my frankenstein setup appears to work ok, the shifter is in a good place and has nice and short throws. I really want to try a frontier/xterra 2WD 6spd transmission to see if that could be more 'bolt-on', but 26", if correct, is a bit too short i think. the ideal location is in the 30 inch mark, and the adapter doesn't add much thickness because we shave 5/8 inch off the bell housing. That is almost opposite of the shortened 350z shifter approach, which is about 3 inches too long (though works for 1UZ i guess!)
couldn't you take another 2 inches off this selector rod by removing the u joint.
either cut and weld or press out the u joint and use the hole for a regular bolt and nut.
Just not sure how well it would shift without it, but if its able to work without it that would be a neat trick.
*edit nevermind you have to keep the u joint in the shifter rod, this guy said he got it to 30".
this is interesting
"might be able to locate the u-joint closer by drilling a new mount hole for the shifter u-joint on the trans shifter rod but still investigating alternate methods of locating the shifter" this makes sense the further you can get it on the rod, the shorter it will be. might have to get a trans and see how short I can get it.
http://forums.nicoclub.com/want-a-6-...575032-30.html
this is interesting
I forget the exact one, but at one point i posted the line i used. It went from the slave to the existing line. It didnt go all the way back to the master. I belive it was a 240 line.
is anyone else in here running the twin disc set up because it seems like I'm the only one running it and that one I cannot shave anything off the transmission is that why I'm having fitment issues to get it in the tunnel?
I feel your pain, but it can be done.
I did not shave anything off the trans on my setup. Nobody mentioned anything about shaving when I did my setup. It's a ***** to get in there. I dread the day I have to take it back out. I did have to hammer the tunnel a bit to get it to fit. I also had to tilt the motor back as far as it would go. Then I was 'barely' able to get it on/off. It was much easier to do with the motor out of the car, but that's not the most realistic approach every time you want to take off the trans.
There is a guy on SF working on a really slick adapter to use a W58 bellhousing on a CD009, which would be amazing!
