2jzge timing
Old Dec 8, 2010 | 04:50 PM
navazsc3's Avatar
navazsc3
Default 2jzge timing
i need to know how to time a 2jzge
i bought a 2jzge with no timing belt on it, basically i need to know what marks should line up with what
i know about the possibility of bending valves yatta yatta yatta
thanks in advance
and yes i have searched but i would like a step by step guide
Old Dec 8, 2010 | 04:54 PM
soarer13oy's Avatar
soarer13oy
cams gear arrows line up to the marks on the black plate and the crank pulley is lined up to the mark on the plastic cover right behind the crank pulley.
Old Dec 8, 2010 | 04:57 PM
S142jz's Avatar
S142jz
2jz Are NON Interference Motors. Unless you have aftermarket cams that are Very Aggressive.
Old Dec 8, 2010 | 05:01 PM
navazsc3's Avatar
navazsc3
gracias!!!!!!!!!
Old Dec 8, 2010 | 05:26 PM
TroySC300's Avatar
TroySC300
thanks in advance
Here ya go buddy
http://www.youtube.com/watch?v=-fiHrC7xT5o
Old Dec 8, 2010 | 06:07 PM
turbodremz's Avatar
turbodremz
^^ Troy beat me to it. Jeff's videos are hands down the best maintenance reference I have ever seen..I would give him a hug if I ever met him (no homo)
Old Dec 8, 2010 | 07:38 PM
Tabaka's Avatar
Tabaka
First time I've seen these videos by Jeff. They are excellent!
Old Dec 8, 2010 | 07:39 PM
SC300_704's Avatar
SC300_704
Jeff's videos helped me out a lot!
Old Dec 8, 2010 | 08:45 PM
Nova's Avatar
Nova
Originally Posted by TroySC300
thats the video i used when i first got my car!!! it is a great help
Old Nov 4, 2011 | 07:58 AM
SCBOII's Avatar
SCBOII
on da crank pulley of da 2jz-ge there r 2 markings for timing, and on da cover behind da crank pulley there are several different numbers. idk which marking and which number on the cover im supposed to line it up at...
is a timing light required to put da car in perfect timing?
Old Nov 4, 2011 | 09:05 AM
6SOARER's Avatar
6SOARER
The 2 marks on the lower timing belt cover are 10degrees BTDC on the left and 0 on the right. To set timing you will need a timing light, click on the bottom link for Halons build, scroll down to post 102.
https://www.clublexus.com/forums/sc-...e-sc300-7.html
JesLet
Jan 21, 2016 02:13 PM
6SOARER
Performance
Oct 5, 2014 08:08 PM
Inspectah
Apr 27, 2008 08:36 PM
