(1992)SC400 egr delete resistor location
Old 09-12-10, 07:13 PM
SexCoupe
SexCoupe's Avatar
Default (1992)SC400 egr delete resistor location
Well first off hello to all
im having a problem locating the sensor im suppose to be putting this resistor in ive searched lextreme,google,and here and no one seems to answer where it goes on a "1992" sc400 i know where it is for the v6s and even the 95 and up v8s but not the 92...
there are three sensors i see one by the diagnostic box(black sensor) and one the exact opposite by the rear intake mani(turqoise sensor) and one behind the intake manifold(grey sensor)
ive tried all 3 with the resistor still throwing the code ive deleted the egr system so im not sure wuts going on ive reset the ecu each time i tried one all i need is some kind of help thanks
Old 09-13-10, 04:54 AM
hershsc400
hershsc400's Avatar
I have a 96 and i place the resistor in the connector of the egr valve itself, and i still have a CEL. I am also wondering where it goes... I've also had this problem for a while.
Old 09-13-10, 05:27 PM
SexCoupe
SexCoupe's Avatar
someones gotta know somthing im not the only one with a 92 sc400???
Old 09-18-10, 05:12 PM
1SICSC4
1SICSC4's Avatar
Well we all know any SC400 regardless of the year has the 4.0 1uz-fe V8. Thats what makes it a 400. There has never been a V6 SC! Do some more research about you car and your motor man.
Old 09-18-10, 11:23 PM
SexCoupe
SexCoupe's Avatar
wtf ??just a typo homie everybody knows what i ment..... garaunteed i know more about both engines than you kick rocks with that lame *** post
MODs if you dont mind...delete this thread since it seems to be useless
Old 09-18-10, 11:50 PM
JakeBreyck
JakeBreyck's Avatar
I deleted my egr by just removing the valve and blocking off the holes in the side of the intake manifold. I didn't have to use any resisters. and no cel, ok well to be fair no egr related cel, i did have a cel from no secondary o2s that i ignored. 1992 motor btw.
Old 09-19-10, 12:43 PM
SexCoupe
SexCoupe's Avatar
wow thats weird redphoenix said the same thing i dont understand why mines is throwing the code.....do u have and pictures of the egr side of the engine by any chance?
Old 09-19-10, 07:42 PM
JakeBreyck
JakeBreyck's Avatar
stock computer, not really the side but you can kinda see.
Heres a good shot of the block off plate.
And heres a current pic, now none of that crap matters, only sensors i have now are crank, iat, water temp, map, and the motor will run with just the cps. now running an electromotive tech-gt ecu.
Old 09-14-13, 12:30 PM
hamzeh1980
hamzeh1980's Avatar
what motor is this
Old 03-13-14, 03:15 PM
oldManTan
oldManTan's Avatar
Originally Posted by hamzeh1980
what motor is this
its a 1uz, what the thread is about?
DJ420a
03-31-19 12:41 PM
deanbrown
22
10-24-18 09:49 PM
archalis
10-09-18 10:22 AM
Crazedshif
10-30-13 12:23 AM
DJ420a
01-03-09 07:35 PM
Quick Reply: (1992)SC400 egr delete resistor location
