Screeching noise
Screeching noise
Okay I know I've posted something like this before talking about the screeching noise on my 94 SC300. But I have noticed something different about it now. Before, I only heard this high-pitched screeching noise when I first started my car on a cold-start (and some times on warm-starts) and turned the wheel when coming out of a parking space. But now, I've noticed that the screeching noise happens REALLY BAD when I have my fog lights/low beams on. I have two 55w HID kits, 1 for my fogs/1 for my low beams. It is weird though, when I have the headlights off, there is little to no screeching noise. If you hear anything with the headlights off, it is very faint, but with them on it is so annoying and loud. I've also noticed that if I cut the wheel all the way trying to get out of a tight parking spot or something it does it too, no matter if the headlights/fogs are on or off. I was thinking it could possibly be the alternator, because the past 2 owners have told me that they had some serious problems with it, and BOTH past owners have replaced the alternator on 2 separate occasions, so now I'm stuck with the problem. So should I look into replacing the alternator? I've gotten the battery and alternator tested before they both tested great. How much does a performance alternator cost? I don't know too much about alternators, but I do know a good bit about batteries. Any help? Thanks guys.
I've heard that before about the belt needing to be changed. I can do that, but I just think it is weird how it makes the noise WAY more louder when I have my headlights on. I would of thought it would be the alternator screeching or something. I've looked at the belt on the front of the motor (2JZ-GE) right near the yellowish fan/radiator and the belt looks fine, still tight and not worn at all.
By the way, just because the belt looks okay, doesn't mean it is. Remember that fluids or material deterioration on the belt face can cause this issue.
In science, one can assume in theory, but must test and prove in practice.
Keeper of the light
This is really not rocket science. There are only 2 kinda of squeals.... bearing or belt. When you load the system electrically and it gets louder, it's the belt slipping on the alternator as the system tries to draw more amps. It doesn't have to be a bad tensioner, the armature in the alt can be worn enough to drag.
very very simple test..... turn on ur car .... get a spray bottle with water... open your hood.. spray water on the belt... does the sound stop???
then its ur belt or the accessorys (alternator/powersteering/waterpump) its attached too... they could be misaligned or worn!
Marqevans
RX - 3rd Gen (2010-2015)
17
06-10-12 02:27 PM
2002, 2jz, alternator, cold, headlights, louder, makes, noise, sc300, sc400, screaching, screeching, sound, start, tensioner
