spark plug & wire replacement help
Old Oct 1, 2009 | 09:17 AM
huddleston's Avatar
huddleston
Default spark plug & wire replacement help
hey guys, the time has come to replace the plugs and wires. i did some looking on pembroke pines trademotion site but couldnt come up with the right part #'s for my 93 SC3. has anyone gone with an aftermarket set up or should i stick with oem?
Old Oct 1, 2009 | 09:46 AM
Carfreak70's Avatar
Carfreak70
The only other "after maket" thing I have seen, wasnt really "after market," just not stock. Some people take the Coil Pack system off of the MKIII 7MGTE because they go turbo and the distributor doesnt fit between the turbo well. If I was you, I would stay stock. These plugs and wires are fine. Get some good plugs and good wires. Wont have to worry about anything else.
Old Oct 4, 2009 | 05:04 PM
ERXRX7's Avatar
ERXRX7
just go to a local autoparts and grab some. Im pushing 450+hp on a set of Bosch wires
Old Oct 4, 2009 | 07:12 PM
labtec's Avatar
labtec
i got a set from http://www.rockauto.com/ --- DENSO brand for about $80
Old Oct 5, 2009 | 12:35 AM
TheMole's Avatar
TheMole
Here you go. You have to look under the ignition system under the mechanical catalog: http://www.trademotion.com/partlocat...93&catalogid=1
Old Oct 5, 2009 | 09:23 PM
t70 supra's Avatar
t70 supra
i just changed my sparks last week my old oem 1 were in my car still had oil and grease on them and 205k miles i cleaned the spark plug galley as well try some ngi iridiums i notice a night a day difference
Old Oct 5, 2009 | 10:10 PM
93twintrbo's Avatar
93twintrbo
I only use Oem Ignition components. Definately not bosch please.
Old Oct 7, 2009 | 07:27 AM
dizzyroc's Avatar
dizzyroc
ngk wire set - 105
ngk plugs - $20
never had a problem with ngk.. and always produced better burn than oem. for me at least
Old Oct 7, 2009 | 08:24 AM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
ngk BKR7EIX if you are turbo.
ngk BKR6EIX if you are stock.
you have to regap them I believe, but these plugs will last you a long time.
you can go with non-iridium if you enjoy changing your plugs more often.
Old Oct 7, 2009 | 12:36 PM
hyjaxx's Avatar
hyjaxx
Don't gap iridium ever.
Stick to OEM for wires.
Old Oct 7, 2009 | 07:23 PM
ronricorum's Avatar
ronricorum
so i just ordered ngk iridium ix. so leave it as in straight from the box and dont gap it? why if i may ask? not trying to be a smart ***, i just didnt know that.
Old Oct 8, 2009 | 10:54 AM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
you can gap iridiums. it is just a little bit harder to...
you have to unless they are already the right gap.
I think if you are stock they might have a set in the right gap. i think they have a -11 or some other number after the name but always double check the gap.
just be sure to buy an extra plug or 2 if you have to regap, because it is difficult to regap them. if you overshoot the gap down and try to "un-gap" them up, they are prone to breaking off.. so gap em down slowly and take your time. i broke the first one (electrode tip actually trying to ungap it) and then did 6 perfect ones down to .024 (for turbo), which is a significant change in gap.
It just takes some patience and some good ol fashioned tapping on a wooden bench.
did the trick for me and man do they run nice.
Old Oct 8, 2009 | 01:29 PM
ronricorum's Avatar
ronricorum
nice ok. just making sure thank you!
Old Oct 8, 2009 | 01:40 PM
t70 supra's Avatar
t70 supra
they sell them pre-gaped
Old Oct 8, 2009 | 01:43 PM
slappy96's Avatar
slappy96
now thats just gross
