Lets talk intake manifolds!
Old 07-09-09, 07:07 PM
DRFT103
DRFT103's Avatar
Default Lets talk intake manifolds!
I'm going NA-T soon and I love the look of an FFIM on a GE with GTE valve covers. I think it's a lot cleaner.
I read somewhere that the N/A manifolds were designed to go over the head like that to produce more torque.
Is that true?
And if so, why would anyone want to go FFIM? I'm assuming it's only beneficial if you're flowing REALLY large volumes of air. (high psi)
Can anyone confirm that the n/a manifold actually does produce more torque?
Old 07-09-09, 07:12 PM
GSXRMack
GSXRMack's Avatar
Can't confirm but this is what is in the FSM, page EM-3. Kinda funny to me because I read it looking for other stuff.
"The intake manifold has six independent long ports and utilizes the inertial super–charging effect to improve
engine torque at low and medium speeds."
Old 07-10-09, 12:05 AM
DRFT103
DRFT103's Avatar
Super charging effect? the swirling momentum of the airflow maybe?
I have no idea.
Old 07-10-09, 07:18 AM
GSXRMack
GSXRMack's Avatar
Me neither brother, That was just what I read two seconds brfore I saw your thread.
Some sport bikes use variable length runners to improve low end with long ones then at higher RPM they slide down to make them shorter.
Some honda motors have basically the same system.
Old 07-11-09, 02:35 PM
GSXRMack
GSXRMack's Avatar
I think one of the main reasons people would rather have a FFIM is so that the cold side piping isn't directly over the turbo.
Old 07-11-09, 08:43 PM
clevercat
clevercat's Avatar
just get one of these and put Turbo.
Old 07-12-09, 01:03 AM
DRFT103
DRFT103's Avatar
OMFG!!!
WANT!!!
name? or is it custom?
Old 07-12-09, 01:39 AM
v8soarer91
v8soarer91's Avatar
design like that you will not be getting the airflow velocity to the 5th and 6th cyliinder.
how it should be done with dyno chart.
http://www.plazmaman.com/shop/index....tem&itemId=311
Old 07-12-09, 09:03 AM
clevercat
clevercat's Avatar
Hey Joy, you might want to study rear of the manifold before making such statement.
It's Ross racing intake manifold for 2jz-gte not for NA-t.
This is the biggest intake manifold for MKIV TT without relocating the battery.
The manifold has narrow back making sure that air velocity carries to all cylinders. Better looking than that plazamanan POS intake.
OF course, it is custom anodized to HKS purple since I am using most of HKS parts building my 2jzgte swapped SC.
Design like that would flow enough to get you 1k hp level with racing gas and many quality parts.
Old 07-12-09, 11:22 AM
Gspec
Gspec's Avatar
You can def expect to loose a ton of low rpm torque when switching from the NA long-runner manifold to a short runner, large plenum design such as that.....If upper rpm power is what your after, go for it.....if this is a daily and you like some low end grunt, stay with the NA.
dawhorl21
47
12-20-18 04:44 PM
darbs242
IS F (2008-2014)
12-14-13 07:01 AM
LB Lex
GS - 1st Gen (1993-1997)
43
03-25-09 02:18 PM
audi2nr
08-11-05 03:42 AM
MyScRuNmIa
07-18-05 10:39 AM
Quick Reply: Lets talk intake manifolds!
