check engine light wiring??????
Anyone have any insight to wiring up the check engine light in an SC300?
Mine is not wired up, th wire coming from the ecu that is labeled "MIL" is cut and goes to nothing, nor does my light come on when I key it over.
I cahnged the bulb for aknown good one and it still doesnt work, im assuming because it is not wired up,
anyone havesome direction for me, I have searched but have found nothing.
my car has an aristo and JDM ecu in it
car is running poorly and I have no way of finding any of the code info
thanks in advance
thanks in advance
Yes, and as a matter of fact, I was supposed to call you today and ask about this, as far as one of your harnesses but got caught up on the dyno for quite longer than I expected.
I was going to ask if one of your harnesses would help me fix this issue.
I was also the guy that sent you an email asking if you made harness extensions
simplecar
RX - 1st Gen (1999-2003)
06-25-19 04:59 PM
