A noob have questions.. Difference between supra 2jz and sc300 2jz
Old 05-20-08, 06:03 AM
TougeSC3
TougeSC3's Avatar
The engine that is in the SC300 and the one found it the MKIV NA Supra are identical. Nothing different between the 2 that I know of.
Engine Code: 2JZ-GE (naturally aspirated) DOHC
Displacment: 3.0 liters (2997cc)
Cylinder Bore: 86mm (3.39in)
Cylinder Stroke: 86mm (3.39in)
Uses Sequential Electronic Fuel Injection
Aluminum head and 4 valves per cylinder
Cast Iron Block
Static compression ratio of 10.0:1
JZ = JZ series engine, 6 cyl gasoline, family of straight-6 engines. Were replacement for M-series motors.
Heres something you didn't know:
After the dash in the engine code GE/GTE have a meaning behind them.
G-Twin Cam (sports/powerful) with multiple sidedraft carbs (unless EFI). Wide Angle, 45 degrees or more between the intake and exhaust valves.
E-Electronic Fuel Injection
T-Turbocharged
The 1 and the 2 and just engine generations. I'm getting off topic. I'm done.
Matter of fact here you go. http://www.mkiv.com/specifications/ncf/ncf93/
Old 05-20-08, 06:56 AM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Old 05-20-08, 07:42 AM
Curry
Curry's Avatar
Supra 2jz comes in the supra and the sc300 2jz comes in the sc300.
http://en.wikipedia.org/wiki/Toyota_JZ_engine
Old 05-20-08, 01:53 PM
Chilkoot
Chilkoot's Avatar
I also seem to recall reading somewhere that the GE and GTE have different heads, GTE being preferable by far.
Old 05-21-08, 12:58 PM
Bean
Bean's Avatar
Originally Posted by joshthorsc
Both Supra and SC300 n/a motor are the same except for the oil pan. If you end up buying a supra n/a motor, you'll need the oil pan off your SC.
Usually when people swap in Supra motors, they are swaping it for the 2jzgte.
The motors are identical through and through. The only thing not identical is the wiring harness connected to it; though it is VERY VERY VERY similar; in fact it only really differs near the ECU plug where it connects to the car's internal wiring system.
Oil pans are the SAME between all motors; the GEs just don't have the oil return hole drilled (nor the bolt holes on either side of it). Supra and SC300 have the same oil pan. They have an identical chassis forward of the driver including placement of the crossmember.
Old 05-21-08, 02:24 PM
laxdude362
laxdude362's Avatar
Originally Posted by OneJay
Lexus FTW! toYota is teh Suxorz!
Dude. Toyota makes Lexus. There is no Lexus in Japan, everything is Toyota.
Old 05-21-08, 02:52 PM
TLDriver
TLDriver's Avatar
I'm taking a wild guess but I think he was joking...
Old 02-17-18, 12:03 PM
Kodiak303
Kodiak303's Avatar
I believe the biggest difference is, the turbo 1,2 jz-gte have lower compression pistons too add more boost= more power.
where as the na jz as higher compression pisions too make up for the power.
Old 02-17-18, 06:49 PM
Kodiak303
Kodiak303's Avatar
Default SC300 oil cap question
I have a 1992 SC300, the oil cap that I have is unreadable. Apparently there are two different caps 1 is 5w30 and the other is 10w30. Can the SC300 drivers kindly let me know witch one you have so I can go ahead and order the correct one.
thanks in advance!
LEXXIUM (11-22-18)
Old 02-19-18, 07:35 PM
shajbot
shajbot's Avatar
Originally Posted by Kaydee
the difference is that the supra 2jz has a toyota logo while the sc300 has a lexus logo
Haha . This reminds me one time at a smog shop, the tech told me I had a LEXUS only engine vs. a TOYOTA engine in his ES330. Little did he know, the same engine is used in a TOYOTA Supra.
Ejsides36
SC- 1st Gen (1992-2000)
13
08-09-11 04:28 AM
socalturbo
02-12-11 11:37 AM
J'sSoarer
18
02-13-08 07:42 PM
DriftNsc3
01-11-06 03:12 PM
2fsturpast
05-09-04 05:59 AM
Quick Reply: A noob have questions.. Difference between supra 2jz and sc300 2jz
