R154 box in JZA80, speed sensor question
Well I am now at the point where I need to sort the speedo out. Its a Supra MKIII R154 box in a JZA80 MKIV Supra. What speedo sensor works with this combo? Source? Price? Cheers guys.
Ok, so I need a MKIV manual speed sensor and an R154 gear to put on the MKIV sensor then an adapter plate to space it, corect?
Would a sensor from an Aristo 1JZ manual not just bolt on and work?
Hmmm ok I have a cable sensor on my R154 box... looks like I could use this?
http://www.marlincrawler.com/htm/tra...ase_ac.htm#vss
sorry for bringing this back from the dead, but that martin crawler vss seems like a plausible solution for people who need to convert cable to electric vehicle speed sensor. Anyone have any experience with this?
I made a small bracket out of some aluminum I had laying around- it took me about 10 minutes to cut, bend, and make the final product.
I used the stock speed sensor from my W58 tranny. I believe that's the same as the speed sensor from my auto 97 transmission too. I'll post some pics tommorrow when I get a chance.
No need to get anything from that Marlin Crawler place- the bracket is VERY easy to make.
Allen
Allen
I used a stock sensor too, just screws on the existing sensor with 3 wire. the Marlin piece really is just replacing the stock Toyota part you can already get from a wreckers for $10. Oh and they take 6 months to reply to any communication, I gave up. I didnt need any bracket?
Oh, I see. Supposing that I don't have a w58 speed sensor, It seems that I can get this marlin adapter much cheaper then buying a new or even junkyard w58 speed sensor. I looked at my r154 vss and I noticed that I can unscrew the cable input. I thought that 4000gt was talking about that particular part. Thanks for the info.
allen,
by any chance did u take a picture of the bracket that you made? i'm trying to figure out how to install the speed sensor.
Allen
Allen
