Check engine and trac light
Old Oct 10, 2001 | 04:44 PM
whosdady's Avatar
whosdady
Unhappy Check engine and trac light
Hey guys,
I just got this 93 SC400 a couple weeks ago. The check engine light and the trac light came on roughly at the same time. They are not always on. However, I took the car in for emissions today and it didn't pass. I took it to the dealership and they said both main o2 sensors were bad. I have two questions:
1. Will the replacement of the 2 o2 sensors fix the probelms associated with the two lights that come?
2. Would that also lower the HC and CO levels that make my car not pass emissions?
Has anyone experienced similar problems?
Thanks for your help.
Old Oct 10, 2001 | 05:49 PM
The Ikon's Avatar
The Ikon
Arrow
Check engine and trac light... That happen to me once after I had my oil changed!!! I had them inspect the car and it was 2 1/2 qt. low on oil... Filled it up and the light went out...
Now I have no idea about the inspection problem.. Could be cats, O2 sensors, bad mufflers, etc... Get a tune up, oil change inspect exhaust system and try again....
Good luck
Old Oct 10, 2001 | 07:51 PM
whosdady's Avatar
whosdady
Thats funny you mention the oil. I have two bad leaks. One from the rear main seal and the other from the trans pan. I know I am low on oil. Maybe that will solve the 2 lights?
When those lights came on, did your trac control work? Mine doesn't.
Thanks for the reply.
Old Oct 10, 2001 | 09:29 PM
methodmf's Avatar
methodmf
I've had the same problem with the lights turning on and off. I never got it checked cause the car runs fine and i read a lot about the engine light turning on with the SC.
Traction Control shuts off if your check engine light is on. So if ur light is on becareful in the rain. I've had a few close encounters.
Old Oct 11, 2001 | 08:29 AM
The Ikon's Avatar
The Ikon
Whosdaddy, I did not get a chance to see if it worked or not. I took it straight back to the shop.
Was it low on oil or not?
Old Oct 13, 2001 | 08:08 PM
whosdady's Avatar
whosdady
Default Yes
Yes it was low on oil but that didn't change anything. I ordered two O2 sensors today. I hope that helps. I will post back when I get them.
Old Oct 14, 2001 | 10:43 PM
The Ikon's Avatar
The Ikon
Good luck and keep us posted...
Old Oct 15, 2001 | 08:54 AM
VQT's Avatar
VQT
Default Re: Yes
How much did you paid for the main O2 sensors? changed it yourself buy the O2 tool from an auto parts store and you're good to go.
Old Oct 30, 2001 | 07:45 PM
whosdady's Avatar
whosdady
Smile trouble lights are gone
I replaced both main o2 senors and the lights went away. The car actual drives better and passed emissions.
I'm happy!
Old Oct 31, 2001 | 08:17 AM
VQT's Avatar
VQT
Default Re: trouble lights are gone
I'm happy!
Did you changed the O2 yourself? It wasn't that difficult to change the O2 sensors.
Old Oct 31, 2001 | 04:30 PM
whosdady's Avatar
whosdady
Default No problems
Yes I did it myself, they just screw in and out.
Old Nov 1, 2001 | 04:49 AM
VQT's Avatar
VQT
Default Re: No problems
Change all fluid including trans. fluid Type T-IV. Got my white SC400 in Feb. change everything except the trans. fluid. Car began to develop shake like run over rumble strips. Changed the trans. fluid last week. car run a lot better now.
I paid $20 for a 4 liter can of trans. type T-IV from Carson Toyota.
atlantis43
RX - 1st Gen (1999-2003)
Sep 19, 2010 11:13 AM
Saiji
Oct 2, 2007 09:12 AM
LexSaZ
Canada
Dec 21, 2006 06:44 AM
Conceptvip
Maintenance
Oct 28, 2004 02:20 PM
Jasoneo5
Mar 6, 2004 02:55 PM
