Pacific For events in California, Idaho, Nevada, Oregon, Washington, Hawaii, and Alaska.
Lexus repair puyallup / tacoma
Old Mar 10, 2011 | 02:26 PM
V8drummer's Avatar
V8drummer
Default Lexus repair puyallup / tacoma
Looking for a shop to diagnose/repair an issue with my 92 sc400. Anyone know of any good local shops, preferably in the Puyallup / Tacoma area? If you know the shop rate too that would be great, not looking to pay 90-100 an hour.
Old Mar 10, 2011 | 08:47 PM
IS3_FTW's Avatar
IS3_FTW
What kind of problems are you having? Im in Spanaway, but not a mechanic
Have you tried an OBD reader from autozone?
If not, then you can either put a deposit on one and borrow it for a day. When you return it, you will be refunded for the whole deposit. Or if your car is driveable, you can use it in there parking lot for free.
Write down the codes and come on here to find out what the issue is.
Old Mar 10, 2011 | 10:46 PM
sway162's Avatar
sway162
My tech works for Lexus. He lives in the south hill area. If you are interested....pm me. I will send you details. I now only do my services through him.
Old Mar 11, 2011 | 12:59 AM
V8drummer's Avatar
V8drummer
Basically it had a misfire that would start and gradually get worse as it got warm. I've replaced spark plugs, wires, coils, caps/rotors, etc. A couple times it has gone away for a few weeks, but then comes back. Now it does it right at start up. It runs very rough, doesn't idle right, etc.
It hasn't been throwing any codes, and do they have one for OBD1?
pm'ed
Old Mar 11, 2011 | 05:13 PM
V8drummer's Avatar
V8drummer
Ended up just taking it to a shop close by. It had good spark, compression, like I thought.
Looks like the #1, 2, and 7 injectors are bad/clogged.
Now my question is should i just buy remanucfactured ones, taken them out and have them cleaned, or take it to a shop and have them run cleaner through them?
Old Mar 24, 2011 | 08:21 PM
macd7919's Avatar
macd7919
I think there is a Dr. Injector in Federal Way that could clean/flow test them for you. Probably same day turnaround.
P.s. - FWIW, stay away from a shop called Illtech in Tacoma, not worth the headache you will get dealing with them.
Old Mar 24, 2011 | 10:33 PM
V8drummer's Avatar
V8drummer
I took it back to the shop that did my shocks/struts, should have gone there to begin with. It actually ended up being the injector wire harness. I had the new injectors put in anyway and new fuel filter. He only charged $150 for everything.
Bimmer2Lex
Southeast
Aug 20, 2017 02:57 PM
IronmonkeY
Southeast
Nov 8, 2016 08:50 AM
theborg
Jan 30, 2015 07:58 AM
yungfras
Southwest
Aug 30, 2014 02:12 PM
