NX - 2nd Gen (2022-current)
2022 NX Door Panel Removal
Old Jul 3, 2022 | 04:20 PM
Mamberly's Avatar
Mamberly
Default 2022 NX Door Panel Removal
Hi folks,
We've ordered NX F-Sport in Atomic Silver, and I plan on adding sound deadening material on the doors panels. I wanted to know if anyone attempted to remove the door panels or knows any instructions on how to do so.
Old Jul 3, 2022 | 07:41 PM
jatwell's Avatar
jatwell
I can’t help with that part, but my ‘22 is pretty quiet. Most of the noise on mine comes from engine noise, which sounds piped in through the audio system, but I can’t confirm that. The way sound travels in cars can be quite deceptive and I’m no expert, but I doubt insulating the doors will help with that aspect.
Old Jul 23, 2022 | 11:27 PM
Mamberly's Avatar
Mamberly
I'm only adding sound deadening materials on the doors to limit the amount of sounds coming from my car. I wanted to limit the amount of the vibration from the doors panels when I'm on the phone (Bluetooth/car play
Old Jul 24, 2022 | 06:42 AM
midcow3's Avatar
midcow3
Lightbulb Dynamat
I have used Dynamat before and it works pretty well. There is a newer and little thicker Noico that might be better. I had it professionally installed and it was relatively inexpensive, several hundred, for only the front doors.
Good Luck and quiet solitude.
YMMV,
MidCow3
Old Jul 26, 2022 | 04:57 AM
Mamberly's Avatar
Mamberly
An Auto Audio shop quoted my $700 for all 4 doors. I've installed Dynamat on my previous two cars, but I had instructions on how to remove the door panels.
I'm just a bit hesitant since I can't find any instruction or service manual on how to remove the door panels.
Maybe i'll wait a few months until I find someone willing to post a video or pictures on how to dismantle their doors
Old Jul 26, 2022 | 03:26 PM
703's Avatar
703
TIS have the service manuals
Old Aug 12, 2022 | 07:25 AM
Mamberly's Avatar
Mamberly
- Update -
I was able to figure out how to remove the door panels by using TIS service manuals ( Thanks 703!)
It was a lot easier than I thought, but removing the service hole cover was a pain! I'm glad I had the right tools for the job.
Old Aug 12, 2022 | 10:45 AM
mbezzo's Avatar
mbezzo
Awesome, thanks for sharing. You take any decibel readings before/after? Very curious to see how much it helps!
Old Aug 12, 2022 | 10:44 PM
Mamberly's Avatar
Mamberly
I didn't do any scientific measurement, but I played the same song (same audio level) before and after. I notice better mid-bass from my ML speakers.
Reducing unwanted resonance and reflections helped out the with the sound quality.
Old Aug 13, 2022 | 11:13 AM
mbezzo's Avatar
mbezzo
ah, cool. So more of a door-deadening/anti-vibration thing than a cabin noise reduction. Makes sense! Where'd you end up installing it? just around the speaker cut out in the door? or the whole door panel?
Old Aug 18, 2022 | 08:16 AM
NTM's Avatar
NTM
Hi, anyone knows the speaker size for the front and rear?
Old Aug 25, 2022 | 01:35 AM
Mamberly's Avatar
Mamberly
I installed the sound materials on the whole outer door panel. I ended up cutting small pieces of long strips rather than large pieces. I find it easier to install smaller piece in confine spaces than large ones.
Old Aug 25, 2022 | 08:25 AM
E46CT's Avatar
E46CT
The "decibel" readings are meaningless, as that's not what *that type* of "insulation" is for. That's not how cars are quieted. That typical "stereo guy" metal-backed mat is for panel resonance and/or car audio. 98% of people get this wrong, including myself for the first 15 years this stuff was "a thing." Quieting cars is very scientific and is a very narrow/particular art, especially today with cars that are, at the design stage, analyzed by the worlds most powerful supercomputers as to hone in on where sound deadening (the kinds car makers employ) techniques would actually work as the manufacturer does not want to add unneeded cost & weight. There are aspects of door characteristics YOU can improve at home, but I wouldn't go too crazy and wouldn't expect too much and certainly wouldn't spend too much. Slivers of openings. Slivers.
Old Aug 25, 2022 | 08:27 AM
E46CT's Avatar
E46CT
- Update -
Those small cutouts, those are what you added? If so, that's fine and on the right track. Or are those the factory parts? I've seen a few different configurations employed by Lexus on various models. There's the law of diminishing returns, too much doesn't do anything so if that's all you did, i'd approve.
Old Jul 21, 2023 | 09:02 PM
usr01's Avatar
usr01
How does one get/log into TIS?
Is there a version of the TIS service manuals that is public and not behind authentication?
