I’m looking to buy winter wheels for my 2022 NX. Anyone know where I can find rims that will fit? I’m curious if RX rims will fit on an NX.
The accessory rims offered on Lexus website are not my taste. I prefer these. Anyone know if they will fit?
Try PMC Tire. They are out east, like Quebec or something. They deliver via FedEx free, rubber mounted on wheels, balanced, TPMS installed if you purchase it.
Just enter your NX in the site and it will give you all available options and size combinations. It will guarantee fitment this way. Just bought a set of summer wheels and tires for the wife's UX, and got here in Markham in less than 5 days.
RWC wheels. Proper offset, correct center bore, correct bolt pattern and made to use existing lug nuts, do not fall apart during winter use. Good solid wheel and a lot cheaper. I have had three sets for a GMC Sierra, no issues.
Can someone confirm if the 1st gen NX 18" wheels will fit on the 2nd Gen.
I know that Lexus changed the from lug nuts to bolts for attaching the wheel to the hub.
The wheel bolt pattern on the 2022 NX is the Lexus/Toyota standard size, 5×114.3 (aka 5×4.5), center bore 60.1. Gen 1 NX had the same bolt pattern, so they should fit.
great tip! Nice wheels and very convenient. Solid pricing as well! I like how they have OEM replicas.
Can someone confirm? My concern is Lexus' change in using bolts rather than lug nuts.
I am looking to buy a set of used 1st Gen NX wheels as winter setup for the 2nd Gen NX.
Last thing I want to find out is they don't fit after I bought it.
If your Gen2 has the 20 inch F Sport wheels (I’m not sure about non F Sport), they have a ball seat that mates with the OEM lug bolt. Unless you can find an aftermarket replacement lug bolt with a flat seat to mate with the Gen1 wheel which also has a flat seat you should not buy,
Yea they're really good, best part is when they arrive it's ready to install providing you have the correct lug bolts for the type of wheel you purchased,. I'm still debating if I should go ahead and get a set for the NX since there is a sale now. Problem is dunno when my unit is arriving. If it comes in September it'd be pretty pointless. It's supposed to arrive June, July but with the apparent Pano roof delay, I don't even know anymore.
Are you planning to order replica OEM wheels with your NX? I only have experience with the RTX wheels, thoughts on RWC/other brands?
For second gen they went to lug bolts with a radius seat from lug nuts used on first gen. I don't think they'll work. You could call Lexus dealer and ask to make sure.
I have a 2025 NX 250 18” wheels but I wanted to move up to the 2024/2025 F Sport wheel which are 20”
does anyone know if the 20” will fit my car?
my rim size is 5x114.4 I believe the bore hub is 60.1
If you mean your new 20" wheels will be 2nd Generation Lexus NX original equipment F Sport wheels for the current generation MY 22-25, then yes they will fit. Both your old and new rims use a wheel lug bolt, which is new for this current generation, so you should be good. I would of course make a quick call to Lexus parts at your dealer just to make sure they're not aware of any issues, I don't think there would be though. Plus new tire should be 235 - 50 R 20 either V or H speed rated.
Here's a handy rim spec site to use. You must make sure you've chosen your correct region (USA) since spec are possibly different around the globe.
