NX - 2nd Gen (2022-current)
TPMS and Tire rotation
Old Apr 9, 2025 | 12:48 PM
P5mmx10g's Avatar
P5mmx10g
Default TPMS and Tire rotation
Do you need to re learn the location of the tire or it updates automatically? let say swapped tires from front to back.
Old Apr 9, 2025 | 01:10 PM
Droid13's Avatar
Droid13
There is a function within the settings on the infotainment screen that initiates the relearn for tire location after a rotation.
Old Apr 9, 2025 | 02:34 PM
oreon333's Avatar
oreon333
Yeah you go to setting to initialize the tire rotation then you drive for a few miles and you will get a notification that it finished.
Old Apr 9, 2025 | 02:43 PM
lsft's Avatar
lsft
Old Sep 15, 2025 | 06:47 AM
Amigo's Avatar
Amigo
Veteran: Navy
I rotated my tires two days ago (@ 10,400) , the TPMS display picked up the new tire location pressures by itself. I was impressed.
Old Sep 16, 2025 | 03:59 PM
Bruce128's Avatar
Bruce128
My experience has been that it takes a while but it will eventually fix itself. If you do the manual reset be prepared that it'll display nothing for a while. It takes a fair amount of driving for it to find the positioning and show the pressures again.
Old Sep 17, 2025 | 04:37 PM
TheCDN's Avatar
TheCDN
Takes my '22 NX350h about 5-10 miles to max to see rotation and or a complete tire-rim swap from snows to summers. I did use OEM TPMS too on my snows so I could be assured everything would go off without a hitch.
The manual states travelling on roadways that have curves will aid in learning process.
Section 8-5 Registration of the position of each wheel after performing a tire rotation:
Step 8
Drive straight (with occasional left and right turns) at approximately 25 mph (40 km/h) or more for approximately 10 to 30 minutes. When wheel position registration is complete, a message indicating that registration has been completed and the inflation pressure of each tire will be displayed on the multi-information display. Even if it is not possible to drive continuously at approximately 25 mph (40 km/h) or more, registration can be completed by driving for a long time. However, if registration does not complete after driving for 1 hour or more, park the vehicle in a safe place and leave it with the power switch in ON for approximately 15 minutes or more, and then perform the driving procedure again.
arf1410
NX - 1st Gen (2015-2021)
Apr 6, 2025 09:23 PM
Joyous56
Nov 27, 2024 11:18 AM
bagwell
Wheels, Tires & Brakes Forum
May 11, 2010 08:36 PM
OAKPLANK
Oct 23, 2006 02:58 PM
