NX - 2nd Gen (2022-current)
Dash cam power adapter
Old Dec 1, 2024 | 05:52 AM
Gta1216's Avatar
Gta1216
Default Dash cam power adapter
I plan to see FitDVR dash cam power adapter so I don't have to run the power cord. Does anyone know if I have to remove the battery and if there will be error codes if the battery is removed and reconnected?
Old Dec 1, 2024 | 04:56 PM
oreon333's Avatar
oreon333
You do not have to disconnect the battery to connect your camera. IF you still want to disconnect, go ahead, but you will get the codes and you will have to re-initialize a few things in order for them to work properly afterwards.
Old Dec 2, 2024 | 03:35 AM
Rathmullan's Avatar
Rathmullan
I would make sure, before doing anything, that you remove the Micro SD card from the camera and only when there are no lights lit on the camera. The camera continues to record for almost 3 minutes after you have powered off the vehicle. I've been through two Micro SD cards trying to insert or remove SD cards while the camera was still operating.
TripFarmer
Nov 8, 2022 04:12 PM
ShanNX
NX - 1st Gen (2015-2021)
Sep 19, 2021 10:32 AM
rog1206
General Classifieds
Mar 9, 2020 01:18 AM
BettyRX
CL of Hawaii
Jul 28, 2017 01:07 PM
Werner05
Jun 17, 2016 12:32 PM
