Inaccurate Dipstick
So on level the dark side is a little lower( maybe higher viscosity) than the clearer side.
Do I need an engine overhauls ? Even with 93 Octane , I get occasional knocking and loss of power.
And i thought Lexus was reliable nad trouble free.
@kukudm thanks for all your help
YMMV,
MdCow3
Yea no problem. Does the oil on lower side of the dipstick drop back to the 2nd dot?
Actually the black color oil bothers me the most. With your fresh oil, they should mix together, instead of showing two different colors. It almost seems like something is preventing the new & old oil to mix together in the pan. I'm not sure, maybe you need to drive the car a little bit more and then check the color again.
YMMV,
MidCow3
P.S. - Mobile 1 Advanced Fuel Economy
I had the same issue, here's my thread I started last year about it.
https://www.clublexus.com/forums/nx-...m-factory.html
Quick summary of what happened to me, I took it to Lexus and the tech checked the oil and said it was overfilled by a quart. Not sure if he went by looking at the dipstick or actually measured the drained oil. After they changed the oil, the level was correct on the dipstick after waiting a few minutes after the car was shut off.
