winter rims RX to NX
Subscribe
May 16, 2023 | 05:56 AM
Hello, i hope I am not posting this multiple times as the site keeps crashing for me.
I have just upgraded from a 2018 RX450h to a 2023 NX 450h+. I still have my old RX winter rims with Pressure sensors - will they work on the new NX? If not the rims at least just the pressure sensors? thanks
Reply 0
May 16, 2023 | 06:39 AM
Probably the wheels will work
https://www.hubcaphaven.com/c/3433/l...eels_rims.html
https://www.hubcaphaven.com/c/8099/l...eels_rims.html
Reply 0
May 16, 2023 | 06:50 AM
thanks! In your links though they never show rims that fit both models
Reply 0
May 16, 2023 | 07:04 AM
Quote: thanks! In your links though they never show rims that fit both models
Similar diameter, same offset and bolt pattern usually a safe bet for them to be exchangeable
Reply 0
May 16, 2023 | 07:51 AM
Did your RX use lug nuts or lug bolts? That could be a point of incompatibility.
Reply 0
May 16, 2023 | 12:47 PM
I had a set of wheels from my 2020 RX350 and was planning on using those for winter on the NX. However, the new generation of RX/NX use lug bolts, not lug nuts, to secure the wheels to the car. I was told that means the previous generation wheels won't work, so I bought a second set of wheels for winter. I sold the RX wheels.
Reply 0
May 17, 2023 | 05:57 AM
If you had an OEM RX wheel, it most likely will not work. If the wheels are aftermarket you will need to look at the seat of the bolts to see if they match the same seat as the new NX.
Reply 0
May 17, 2023 | 01:30 PM
OEM wheels of old NX / RX will not work on new NX / RX.
I do not believe the TPMS sensors will work either as the new car has different technology.
Reply 1
May 17, 2023 | 02:19 PM
Lug bolts for each style of wheel are $25 from your dealer, tire store, Amazon, etc.
Reply 0
May 18, 2023 | 03:53 AM
You can easily order lug bolts from Tire Rack or a similar tire place.
Reply 0
May 18, 2023 | 06:00 AM
Half the people say new lug bolts can be had anywhere, the other half say no can do, would require converting back to studs to use the old lug nuts. I have yet to come across lug bolts that would work with my old RX wheels (or so it seems so far).
Reply 0
May 18, 2023 | 06:24 AM
Quote: You can easily order lug bolts from Tire Rack or a similar tire place.
Would you have a part number for a lug bolt with flat washer that works with the old Lexus/Toyota Alloy wheels?
Reply 0
Subscribe
