NX - 2nd Gen (2022-current)
Wheel Lock Bolt Stripped
Old Apr 11, 2023 | 08:33 AM
FWCA's Avatar
FWCA
Default Wheel Lock Bolt Stripped
I purchased a new set of winter tires and rims from a local tire shop 4 months ago. When I tried to change over the tires back to all-season, I discovered one of the lock bolt got stripped after I swapped out 3 tires myself already. I know that one cannot use impact wrench on lock bolt/nut so I was not the one who stripped it. I took the car back to the tire shop and they just denied their responsibility as I have done work on them myself. They claimed that they have no tools to extract a stripped bolt too. I ended up taking my car to my mechanic. The mechanic hammered a socket over the stripped bolt and extracted it out. He also replaced the other 3 lock bolts with regular bolts.
If you buy new tires or taking it to a shop for tire swapping, check the lock bolts right after.
Old Apr 11, 2023 | 08:41 AM
Doug007's Avatar
Doug007
Sorry this happened to you but thanks for the heads up. I just had ours switched out and am going to check them out for any damage.
Old Apr 11, 2023 | 09:17 AM
E46CT's Avatar
E46CT
It's very easy to strip out lug nuts/bolts if the tech is rushing, and/or using the wrong tool or an unoptimized tool. or using the right tool in a wrong way. so yes good advice inspect everything before and after. take pics before and after.
maniax
Wheels, Tires & Brakes Forum
Jun 12, 2012 12:52 AM
schwarz
Jul 23, 2011 05:38 PM
aznpapaya
Oct 20, 2010 09:52 PM
dbullen
Feb 17, 2006 10:47 AM
solo
24
Dec 18, 2005 09:32 PM
