NX - 2nd Gen (2022-current)
Permanent delete of Start/Stop feature in NX
Old Apr 4, 2023 | 07:47 AM
lalexusgs's Avatar
lalexusgs
Default Permanent delete of Start/Stop feature in NX
Maybe I searched for the wrong keywords, but I couldn't find anything on possibility to disable automatic Start/Stop feature in 2nd Gen NX. I know different brands have different solutions to it - hardware devices plugged in, fuse removals, etc..I tried to google but couldn't find anything for NX. Does anyone know of any solution for NX?
Old Apr 4, 2023 | 08:04 AM
Randyp1234's Avatar
Randyp1234
If only it were possible. But I don't think so, yet.
Old Apr 4, 2023 | 10:07 AM
FastFord's Avatar
FastFord
https://www.clublexus.com/forums/nx-...t-disable.html
Old Apr 4, 2023 | 11:36 AM
lalexusgs's Avatar
lalexusgs
That thread doesn't really have a solution either
Old Apr 4, 2023 | 01:17 PM
jardlr's Avatar
jardlr
Has anyone been able to successfully open up the center console to get to the start/stop switch? I'm still afraid to break a retainer clip or something.
Old Apr 4, 2023 | 02:12 PM
FastFord's Avatar
FastFord
Sorry I meant to say that....no solution yet.... but the topic had been discussed.
Sorry brain fart..again!
Old Apr 7, 2023 | 08:26 AM
Batty's Avatar
Batty
My NX350 pretty much never goes into stop mode unless I press hard on the pedal. Compared to other s/s I have dealt with, this one is very unobtrusive.
Old Apr 7, 2023 | 12:41 PM
Xanadu350's Avatar
Xanadu350
Is there an option to turn it off one time when getting in? Or is it always on?
Old Apr 7, 2023 | 01:08 PM
Droid13's Avatar
Droid13
There is a button to turn it off, but it comes back on automatically with each trip.
The S&S system is actually not too bad, it is fairly easy to control with brake pedal pressure. I can properly decide to keep engine running or activate the S&S about 90% of the time. Still slightly annoying at the start delay, but it can be anticipated by slightly reducing pressure on brake pedal to let the engine start before its time to proceed. The most annoying thing I've come across is coming to a stop when my trip is complete. The engine will stop but as I put it into P and reaching to turn off the ignition the engine starts again 1 second before I turn it off. A bit dumb there.
Old Apr 7, 2023 | 02:10 PM
blueless's Avatar
blueless
Question Off while in D
I saw somewhere that you don't need to put it in Park when you turn off the engine. The car will go into Park by itself. If that's the case, then you can turn off while in Drive.
Old Apr 7, 2023 | 02:35 PM
Xanadu350's Avatar
Xanadu350
Has anyone does a comparison on a full tank of gas using the auto start stop all the time vs a tank of not using it at all to see if you really save gas? Longer range of miles using it?
Old Apr 7, 2023 | 03:22 PM
DaveGS4's Avatar
DaveGS4
Administrator Emeritus
A study done by SAE in 2018 found it saved over 8% (not NX but generically in vehicles they studied).
Old Apr 7, 2023 | 11:32 PM
LilyTiger's Avatar
LilyTiger
I’ve experienced myself 95% of the time that when I arrive at home (I’ve saved my home address in the navigation system destinations) the engine will not auto stop. Works everywhere else and stops everywhere else as intended, but just not at home. I vaguely remember reading somewhere that this is by resign. Anyone else experienced this?
Old Apr 8, 2023 | 04:23 AM
CdO's Avatar
CdO
Some Tacoma enthusiasts have a similar annoyance. Search for something like Tacoma ECT PWR button fix.
As I recall someone came up with a delay timer that powers up on ignition and triggers the button. (You'll have to have access to the wiring.)
Old Apr 14, 2023 | 12:46 AM
VernonDarr's Avatar
VernonDarr
1st Gear
Spoiler
Have you found the solution?
