NX - 2nd Gen (2022-current)
Socket Size
Old Mar 13, 2023 | 06:35 AM
FWCA's Avatar
FWCA
Default Socket Size
Spring is coming. It is time to thing about swapping tires back to all season. What is the size of socket should I use for the lug bolts? I tried with a 17 mm but it is a bit loose.
Old Mar 13, 2023 | 08:39 AM
Doug007's Avatar
Doug007
Perhaps check another socket? I'm pretty sure it's 17mm.
Old Mar 13, 2023 | 12:38 PM
43sbest's Avatar
43sbest
17mm is correct.
Old Mar 13, 2023 | 01:25 PM
CaptAngry's Avatar
CaptAngry
I use a thin-wall 17mm w/ an anti-scratch urethane cover to prevent scratches.
Old Mar 13, 2023 | 03:10 PM
FWCA's Avatar
FWCA
I have a chrome 17mm so I need to shop for an impact resistant one and a guide pin. Thanks guys!
Old Mar 13, 2023 | 08:06 PM
43sbest's Avatar
43sbest
Buy 2 alignment pins, Take out a top and bottom lug bolt and put in 2 alignment pins-----------------much better than using 1. There cheap on Amazon.
Old Mar 13, 2023 | 10:25 PM
IntrinoX's Avatar
IntrinoX
Are you asking what size your lug nut takes?
Or are you asking what size socket should you use/buy for your wheel?
Old Mar 14, 2023 | 07:30 AM
FWCA's Avatar
FWCA
I was looking for the size of the socket.
Old Mar 14, 2023 | 07:31 AM
FWCA's Avatar
FWCA
Good idea! Is the guide pin size M14 x 1.5?
Old Mar 14, 2023 | 07:32 AM
IntrinoX's Avatar
IntrinoX
That’s not socket size. That’s the lug stud sizing.. If 17mm is too small, then try 19 or 21mm.
Old Mar 14, 2023 | 02:06 PM
43sbest's Avatar
43sbest
The correct sized socket for removing the "lug bolts" on the 2022-2023 NX is 17MM. The lug bolt is an M14X1.5.
Old Mar 14, 2023 | 02:09 PM
FWCA's Avatar
FWCA
Thank you!
Old Mar 14, 2023 | 07:29 PM
43sbest's Avatar
43sbest
Yes, M14X1.5
Old Mar 16, 2023 | 06:59 PM
SgtLip's Avatar
SgtLip
@43sbest Do you have an Amazon link for the Pins?
This is ALL new to me. I haven't had PINS on any of my ES's I have or have had over the years. I'm picking up my NX 450h+ on 12-15 April.
Old Mar 16, 2023 | 07:02 PM
SgtLip's Avatar
SgtLip
@CaptAngry The sockets you mentioned, did you purchase it/them with the scratch protection or is this something you use somehow? I have never heard of this before. I'm interested in finding these. Do you have a link to where you got them? If so, would you share?
Thanks in advance.
