NX - 1st Gen (2015-2021)
Micro SD Card location
Old Sep 28, 2022 | 08:28 AM
MrBasher's Avatar
MrBasher
4th Gear
Default Micro SD Card location
Hi Folks,
I know this has been asked before as to where the MicroSD location is, I have seen a post that says there is a panel and to press the two points on it to open it up. I have the panel but there is no way I can see to remove it, my car is a NX300h 2014 plate but 2015 build. Can anyone assist please?
Regards,
Dave G
Old Sep 28, 2022 | 07:41 PM
GS3Tek's Avatar
GS3Tek
Welcome aboard.
See here, credit to our moderator corradoMR2
Old Sep 29, 2022 | 03:06 AM
MrBasher's Avatar
MrBasher
4th Gear
Hi, Yes, I have seen that, I have the same panel but there are no push points, tried pushing all over it but no joy
Old Sep 29, 2022 | 05:28 AM
Lex2000TL's Avatar
Lex2000TL
Try to push on two tabs/bumps (where arrows are pointing) and the panel should swing horizontally.
Old Sep 29, 2022 | 06:59 AM
Rjngo's Avatar
Rjngo
You pull it up using the nub on either end…I can use my finger no problem but if it helps you, try using some rubberized garden glove 🧤
Old Oct 7, 2022 | 02:43 AM
MrBasher's Avatar
MrBasher
4th Gear
Hi,
As you can see from my image there is nothing to pull, push and I am at a loss.
Old Oct 7, 2022 | 06:15 AM
Lex2000TL's Avatar
Lex2000TL
Does your car have navigation system? If it is does not, there is no SD card as well, so nothing to open.
Old Oct 8, 2022 | 02:52 AM
MrBasher's Avatar
MrBasher
4th Gear
I could be wrong,
but I think this is a map!!!
Old Mar 11, 2024 | 07:43 AM
OkanParov's Avatar
OkanParov
1st Gear
Default Any news?
I have same issue! Could you sort it out?
QUOTE=MrBasher;11374608]I could be wrong,
but I think this is a map!!![/QUOTE]
veeinc
ES - 7th Gen (2019-2025)
21
Sep 27, 2023 09:59 PM
sjowett
RX - 3rd Gen (2010-2015)
18
Oct 10, 2019 04:39 PM
nmnunna32
Sep 16, 2016 06:28 PM
stock300
Dec 7, 2002 10:19 PM
