NX - 1st Gen (2015-2021)
Incessant Rattling from Center Stack
Old Apr 17, 2022 | 11:47 AM
orihara1's Avatar
orihara1
Default Rattling from Center Stack - NX 200t
Hi! I'm new here and I have a 2017 Lexus NX 200t. Lately, I've been dealing with a very annoying rattling noise coming from the center dash / infotainment area.
The best way I can describe the noise is that it sounds like plastic-on-plastic rubbing due to road vibration. Every time I go over any kind of uneven pavement, the rattling can be heard. The pavement doesn't even need to be that bad for the rattling to start up. It is especially noticeable in cold weather, where just the vibration of the car moving causes this rattling noise.
I've taken the car to the dealer but they claim they cannot reproduce the noise...
It's very intrusive and makes driving my car very unpleasant. Does anyone have any idea what could be causing this and/or any possible solution? I've attached two video recordings of the noise when I was driving yesterday (turn the volume up and if you ignore the road noise, you can clearly hear the high-pitched rattling). I can definitely tell that it's coming from the infotainment area and my phone is laying face-down in front of the center screen.
Thank you, everyone!
File Type: mov
Old Apr 19, 2022 | 08:46 AM
xcanuk's Avatar
xcanuk
I only hear road noise...
Can't help you, but I would press firmly on small areas of the dash when you hear the rattle and try to isolate the location further.
Old Apr 19, 2022 | 10:40 AM
orihara1's Avatar
orihara1
Hi...
When I press anywhere on the center stack (where the radio, A/C, etc. controls are) the whole things creaks like cheap plastic.
Old Apr 19, 2022 | 06:04 PM
Lex2000TL's Avatar
Lex2000TL
i had similar issue with plastic trim right in front of display. Apparently there was a TSB for this issue and it was fixed under warranty. Dealer applied some sort of sticky tape between this trim piece and the lower part of screen (not sure if this is exact description, see yellow-circuled area).
jmone22
ES - 7th Gen (2019-2025)
17
Jun 1, 2023 09:40 PM
iamraj1984
Oct 30, 2014 10:15 AM
kim812251
RX - 1st Gen (1999-2003)
Jul 15, 2010 08:13 PM
everton
RX - 3rd Gen (2010-2015)
Apr 20, 2010 05:34 PM
bluemr2
Aug 4, 2005 01:01 AM
