NX - 1st Gen (2015-2021)
Vibrating License Plate Frame
Old Jan 20, 2022 | 11:11 AM
PearlNXt's Avatar
PearlNXt
Originally Posted by JermSJ
I am also having some rattling sound issues on my 2019 NX300. Mine sounds like it is coming from the right passenger side area and it is a slight vibrating sound that I cannot specifically pinpoint. Did the replacement of glove compartment door solve this rattling issue for you? This is for @PearlNXt and the picture of the invoice that you posted above.
That was not me who posted that
Old Jan 20, 2022 | 12:35 PM
Onekoolguy's Avatar
Onekoolguy
No, the rattling issue was not solved after they replacing the broken tab. I had to come back 2 more trips before they finally found the rattle coming from the passenger A pillar and fixed it. Those are the only issues I had with my NX. It's been a great car now after almost 6 years. @JermSJ
Old Jan 20, 2022 | 03:44 PM
zigsch's Avatar
zigsch
Originally Posted by PearlNXt
I just ordered the silicone plate frame from Amazon, this looks like it will totally solve the issue since the plate itself also lays on the silicone. THANK YOU
Did it arrive? Get it installed? Let us know if the problem is solved.
Old Jan 21, 2022 | 10:38 AM
jlfirehawk's Avatar
jlfirehawk
I got mine last night, I got one that has the drains but it was already too dark out to throw it on. Gonna get it done tomorrow and will post an update. I also ordered a black stainless set of new screws which are due in tomorrow since the ones I have on from when I bought the car are rusting a bit.
Old Jan 21, 2022 | 03:50 PM
Lex2000TL's Avatar
Lex2000TL
Originally Posted by jlfirehawk
... I also ordered a black stainless set of new screws which are due in tomorrow since the ones I have on from when I bought the car are rusting a bit.
I would get plastic screws. Available in every parts store.
Old Jan 22, 2022 | 12:50 PM
jlfirehawk's Avatar
jlfirehawk
Got mine installed, I lost the tinted plate cover but the loss of the rattle totally makes up for it.
Silicone Plate Silicone Plate
is the one I purchased from Amazon, although it comes with two and I don't have to use a front plate in my state so I have an extra.
Old Jan 22, 2022 | 01:00 PM
zigsch's Avatar
zigsch
Got mine installed, I lost the tinted plate cover but the loss of the rattle totally makes up for it. Silicone Plate is the one I purchased from Amazon, although it comes with two and I don't have to use a front plate in my state so I have an extra.
In Massachusetts we have plates on the front and rear. I used both silicone covers/sleeves/frames (whatever they're called) and I actually think they look pretty good. I have black plastic screws too so I won’t get rust in the rough winters we have.
This is a crazy long thread for such a minor, easily solvable issue!
Old Jan 22, 2022 | 08:08 PM
GS3Tek's Avatar
GS3Tek
On a car that doesn't give too much problem, complaining about a license plate rattling might be a good thing
Old Jan 23, 2022 | 03:42 PM
End1ess's Avatar
End1ess
Can I still install a clear cover on top of the silicone frame?
Old Jan 24, 2022 | 04:25 AM
jlfirehawk's Avatar
jlfirehawk
You probably could but I didn't try putting my tinted one back on for the whole purpose of getting rid of the rattle with the subwoofer.
Old Jan 24, 2022 | 09:41 AM
zigsch's Avatar
zigsch
Maybe you could on top of the silicone. The silicone kind of wraps tightly around the edge of the license plate. I don’t think you could fit a clear cover under the silicon. But over it maybe. I don’t use any license plate cover on the front or rear.
Old Jan 24, 2022 | 09:51 AM
LEXNXF's Avatar
LEXNXF
I had the same thing right away! I love to bump my music, I just got a silicone license plate frame from amazon for the rear plate. Problem solved.
Amazon Amazon
Old Jan 26, 2022 | 01:15 PM
DOUGLis350's Avatar
DOUGLis350
I just added this too. The plate doesn't lay flat it is kind of warped with the plate in. Not sure if anyone else noticed that.
Old Jan 26, 2022 | 02:16 PM
LEXNXF's Avatar
LEXNXF
Didn't notice that, mine seems to work just fine and solved that issue for me.
Old Jan 28, 2022 | 02:04 PM
PearlNXt's Avatar
PearlNXt
Installed the silicone pate frame last week, solved it 100%!!
