NX - 1st Gen (2015-2021)
Fog light bulb replacement
Old Oct 3, 2021 | 04:56 AM
geomike's Avatar
geomike
Default Fog light bulb replacement
Hi, i have the left fog light on nx300 2018 off. How to replace it ? Or is it a fuse thing? Where is the fuse located ? Thanks
Old Oct 3, 2021 | 09:48 AM
n0v8or's Avatar
n0v8or
The fog lights are not separately fused. There is a single 7.5 Amp fuse for both. If one is still working, then the issue is not the fuse.
Lexus recommends to remove the entire front bumper assembly to replace a fog light. It may be possible to accomplish the replacement by just partially removing the bumper on one side. I recommend using the forum search function to check if anyone has done this successfully.
Old Oct 5, 2021 | 07:45 AM
NX200t16's Avatar
NX200t16
If you look on the bottom of the bumper you'll see a small access panel right under the fog light, however I don't believe there is a replacement part for the bulb itself, I'm pretty sure its the whole housing that gets replaced. If I'm wrong please post pics and part numbers that you use to replace said bulb. Thanks!
Old Oct 5, 2021 | 08:01 AM
Neverlost's Avatar
Neverlost
What a load of crap. Remove the bumper? This should fall under the right to repair! The fog lights are so worthless to begin with I came here to see if there was a way to improve them. Forget it, I would rather just drive in the daytime.
Old Oct 6, 2021 | 01:04 PM
NX200t16's Avatar
NX200t16
You clearly didn't read my post..........
Bahchu
Jun 4, 2020 04:30 PM
wopdud
Nov 5, 2012 12:23 AM
kewpkewp
Sep 10, 2012 03:06 PM
lexus114
RX - 1st Gen (1999-2003)
Feb 18, 2008 09:34 AM
