Engine oil leak, 2015 NX200t
I read the entire thread, always do. I don't care if its been in there 500 or 10,000 miles, the sooner the crap additives are out, the better.
The concern is for a gradual process of unwanted deposits. Just because there is no issue after 7,500 miles dosent mean there hasn't been a negative effect than can be abated by taking action. "As soon as possible" isn't a life or death immediate action, it's as soon as he/she can get around to it for the best interest of his/her vehicle.
My comment was originally directed at post #8. I am not sure if or when an oil change was performed.
The OP can do whatever they want and I have zero investment on whether or not the engine has any ill effects but the last thing I would want to do is not provide advice and just take a "wait and see" approach with someone else's valuable asset.
I second that, oil stop leaks additives are a coagulant, it thicken up in small areas to stop leaks. With the modern day engines, the machining tolerance is very tight. that's is one of the reason, most new engines use a very thin oil, to get inside those tight spots, Now, if your oil additive starts to coagulant in those small tight spot, it can cause all kind of problems down the line not to mention voiding the warranty.
Perhaps this additive still not healthy to turbo, but I searched and did not find any data supporting this notion.
Oil stop leak additive is not coagulant. Coagulant is "a substance that causes liquid to coagulate" and you assumed that this additive will help in plugging leaks. Oil stop does not do that. It has an additive to restore seals that became hard and shrunk over time.
2015 NX200t f sport with 110000kms.
Has gone in today to have oil leak checked out.
In 11 years of Lexus ownership and multiple vehicles, this is the first out of warranty repair required for any vehicle
2016 Lexus NX200T FSport leaking in the Rear Main Oil Seal. Where do I pour the AT-205? And how many bottle do I pour?
[QUOTE=Lexass2020;10931658]I smacked a bottle of AT205 and had it operated for close to about 250 miles. The leakage seems to be improving slightly but not completely plugged. Hopefully will see similar results as you once it hits 500 miles.[/QUOT
hello, I have the same issue on my 2016 NX200T. How does it go right now? Did you pour it in the oil fill plug/hole?
