NX - 1st Gen (2015-2021)
Current Miles on your NX?
Old Feb 16, 2019 | 06:58 AM
ukrkoz's Avatar
ukrkoz
Originally Posted by catchtanya
Im pretty sure plugs are every 40k miles. Check the maintenance guide.
Plugs are due 1st time at 40K miles... indeed. VERY unusual for Ir tipped NGK. So is brake fluid flush at 30K.
Old Feb 16, 2019 | 08:10 AM
Danny200t's Avatar
Danny200t
Originally Posted by chezgk
04/2015 NX200t @ 28,000 Km / 17,500 mi
- Oil and filter changed every 5k Km
- Air filter replaced once at 10k Km
- OEM Akebono front pads wore out after 11k Km, replaced with EBC Yellows (wore out after 25k Km), subsequently replaced with Hawk HPS 5.0
- OEM rear pads half worn at 11k Km, replaced with genuine Toyota part and still ok
- OEM brake fluid boiled during spirited driving and was subsequently replaced with aftermarket DOT4 via Techstream. Gets replaced annually or whenever it boils, whichever comes first.
- Hit nasty pothole at around 24k Km. Caused annoying clunk. Replaced lower control arms, ball joints, outer tie rods, rack ends, stabilizer links, and front left wheel bearing to no avail. Replaced all AVS shock absorbers to no avail. Turned out the pothole just knocked the F-Sport lateral damper loose. Now have an extra set of AVS shock absorbers. lol
- Replaced original tires with GT Radial Champiro HPYs (paired with aftermarket wheels) and eventually installed Toyo Proxes St-IIs since the GT Radials were about to expire.
Were those suspension parts covered under warranty? or did you have to pay out of pocket for all that?
Old Feb 16, 2019 | 08:16 AM
rVague's Avatar
rVague
2015 with 17,000 miles. Zero problems.
Old Feb 16, 2019 | 09:35 AM
fredw1's Avatar
fredw1
Originally Posted by TechNut
2016. Three years this very month. 10,600 miles. Zero issues, but not surprising at such low mileage. Quite a bit of road noise compared to other Lexuses we have owned - but that is just the nature of the vehicle.
Ditto on the road noise and low mileage. I just hit 10K after 19 months.
Old Feb 16, 2019 | 09:50 AM
ross7777's Avatar
ross7777
Nobody seems to drive very much.....
Those with road noise, what tires do you have?
Old Feb 16, 2019 | 11:04 AM
crankshaft's Avatar
crankshaft
I found the same to be true with the standard tires that they had. I had michelins at first, ran into an issue when them shaking so the local dealership swapped them out for Yokohamas. I dealt with those for a while and then when it was time to replace them went with a cooper brand tire, better, not great. Just this past week I took the risk and put on the Vredestein tires, and surprisingly both the ride and the noise level have greatly improved! i was quite surprised and shocked!
VREDESTEIN
QUATRAC 5
Just had my oil change the other day, 10,112 miles. Dealer replaced the cabin filter & I replaced the air filter.
Tires are LOUD....Stock Yokohama Geolandar 91...not happy!
Old Feb 16, 2019 | 11:41 AM
ross7777's Avatar
ross7777
I have the Geolanders and yes they are not great.
Old Feb 16, 2019 | 09:32 PM
TechNut's Avatar
TechNut
Veteran: Navy
I just retired so hopefully I will drive more now, but my office was only six miles from the house so the miles didn’t pile up very fast. We do have some road trips planned...
Anyway, to your question, we have the Michelin Primacy MXM4 tires.
Old Feb 17, 2019 | 06:13 AM
Boomer80's Avatar
Boomer80
Just picked up my 2016 with 28k. I’ll be piling on a lot more miles than the original owner.
Old Feb 17, 2019 | 07:16 AM
ukrkoz's Avatar
ukrkoz
Your brake fluid flush is due in 2 000 miles and you can NOT DIY it. Need scanner for that.
Old Feb 17, 2019 | 06:40 PM
chezgk's Avatar
chezgk
Out of pocket. Brakes and suspension aren't covered by Lexus warranty here in the Philippines.
Old Feb 18, 2019 | 05:24 PM
Danny200t's Avatar
Danny200t
Wow, how much did all that cost if you don’t mind me asking. I believe that all suspension components are covered under bumper to bumper warranty here in North America
Old Feb 18, 2019 | 07:57 PM
no1SomeGuy's Avatar
no1SomeGuy
There are reasonably affordable scanners that can do the EBP. There's also a manual procedure in the shop manual for it.
Old Feb 19, 2019 | 11:13 AM
1Putt's Avatar
1Putt
2016 with 33,000 miles. Regularly maintained initially at dealer and then indy specialist afterwards. Only issue has been passenger front door lock actuator replaced under warranty.
Old Feb 19, 2019 | 02:57 PM
ukrkoz's Avatar
ukrkoz
Is there? That will bleed brake actuator safely? Which reasonably affordable scanner will move actuator valves? I'd like to have that one.
