NX - 1st Gen (2015-2021)
Downpipe
Old Jul 28, 2018 | 10:36 AM
aa146's Avatar
aa146
This replaces the cat tho right?
Old Jul 28, 2018 | 10:43 AM
Esus450's Avatar
Esus450
Catless downpipe 😺
Old Jul 29, 2018 | 08:05 AM
ukrkoz's Avatar
ukrkoz
Originally Posted by Sheddy
That dyno posted above was from my car which is an IS200t with a PPE downpipe, FTP charge pipe, TTI turbo muffler delete and K&N drop in filter. Those results are power to the wheels with the stock tune and BMS stage 1 or comparison.
And this is relevant to NX200t how?
Old Jul 29, 2018 | 10:30 AM
Sheddy's Avatar
Sheddy
They both share the same 8AR-FTS motor. Please do research
Old Oct 10, 2018 | 11:41 AM
VuSpec's Avatar
VuSpec
Any videos or sound clips?
Old Aug 7, 2020 | 11:30 PM
Elhai's Avatar
Elhai
Default May I kindly order one too.
Kindly share a link or contact where I can order a downpipe for the NX200t
Old Mar 26, 2021 | 01:10 PM
Popcaan200's Avatar
Popcaan200
Default Nx200t
Originally Posted by Esus450
Btw, thank you for the advice with the O2 sensors in your previous post in the IS200T downpipe section. It's help me the fix the CEL.
Im thinking about the burger chip. Easy to install and remove and the gain look reasonable. I think you also have this chip install on your IS ?
is it possible I can buy Nx200t downpipes from you guys? I been searching for almost a year now for some downpipes and you guys are the only one that did it. I can be contacted by email at Hollingerc@yahoo.com I’m in New York. Or if you know where I can that’s great as well I appreciate you time and response.
Old May 26, 2021 | 02:57 AM
chezgk's Avatar
chezgk
New downpipe installed! More details here.
Comparison of the bits. I only installed the main downpipe and reused the middle and rear pipes.
New downpipe is a lot wider than the factory bit. Cat looks a lot less restrictive, too.
Target and measured air-fuel ratios in agreement (except on throttle lift) = no boost creep and lean out!
eicca
Performance
15
Sep 2, 2016 09:58 PM
MDHLexus
Performance
24
Feb 22, 2015 04:18 PM
bacardi
Jun 16, 2011 12:12 PM
Jacobond
Jun 16, 2007 04:58 PM
