NX - 1st Gen (2015-2021)
Spark Plugs
Old Apr 7, 2019 | 02:06 PM
mps2220's Avatar
mps2220
Replaced the plugs today and had 3 of the 4 Ignition Coils separate at the rubber boot (Red Arrow Below). There is a small terminal (looks like a solid copper fuse link) that sits inside-between the top of the coil tube spring and the actual Coil/housing. Luckily it landed next to the spark plug hole when everything separated. With all pieces disconnected and removed from the spark plug (Top of coil, connection fuse link, and rubber tube assembly) re-insert the terminal (loose) link so it rests on top of the spring then gently twist and allow it to pop back together.
Continue,
Verify gap .036
No Anti Seize
Torque new Spark Plug to 18ft lb
fastegg
Jul 29, 2014 03:20 AM
amerquresh
Jul 29, 2011 07:31 PM
Pushnoy
Hybrid Technology
Dec 22, 2010 01:48 PM
cheez
Apr 20, 2010 05:43 AM
Ghetto-Pimp
Sep 16, 2002 04:09 PM
