NX - 1st Gen (2015-2021)
Messed up with navigation display..
Old Nov 2, 2015 | 06:12 AM
ho52806's Avatar
ho52806
Water shouldnt cause that? In fact I usually use the towel I dried my car with to wipe the dash down. The towel is moist but didn't think it would harm the screen. Im sorry that happened but thanks for letting all of us know.
Old Nov 2, 2015 | 06:50 AM
Joeb427's Avatar
Joeb427
double post
Old Nov 2, 2015 | 06:52 AM
Joeb427's Avatar
Joeb427
Originally Posted by NXOwner
Not on the NX nav screen, you didn't.
Not on the new screens but on my'15 RX and other Lexus models.
Why?
Would there be a problem using Plexus?
A light mist on the screen or on MFer and wipe.
Old Nov 2, 2015 | 06:57 AM
Tom59's Avatar
Tom59
I would not use any chemical based sprays on electronic screens , period. Not unless someone else did first and you watched them and it worked.
They should definitely have a do not use liquid warning on the display ........
I think your dealer might help you out - I'd certainly give'em hell and then call corporate ...if no results. Be a squeaky wheel see if you get oiled.
Old Nov 2, 2015 | 07:03 AM
Tom59's Avatar
Tom59
Why?
Many new electronic screens have filters and coatings on them this appears to be one. If it gets behind the coating -nightmare!
I also believe this is a design flaw.....
Old Nov 2, 2015 | 07:10 AM
Joeb427's Avatar
Joeb427
Wow!That's stinks.
Plexus is used on many plastics without an issue but I can understand not wanting to take a chance.
Old Nov 2, 2015 | 07:18 AM
LexBob2's Avatar
LexBob2
Are there any precautions or guidelines for cleaning in the owners manual? This sounds like a real problem.
Old Nov 2, 2015 | 07:44 AM
Naren's Avatar
Naren
Originally Posted by typocl
please post pictures if you end up having to remove the rest of the coating
ya sure i will upload
Old Nov 2, 2015 | 11:00 AM
NXOwner's Avatar
NXOwner
From: Driving a UX Hybrid F-Sport! (in So California)
Why?
Any moisture on these screens are BAD for them. I know first-hand. Click here to see what happened to mine.
Old Nov 2, 2015 | 11:49 AM
Joeb427's Avatar
Joeb427
Outside or behind the scren damage.Sprayed on or wet cloth use?.If behind the screen,the seal should be better if so.
Old Nov 2, 2015 | 12:12 PM
NXOwner's Avatar
NXOwner
In my case, I suspect that my car wash place oversprayed windshield cleaner on it when cleaning the inside of the windshield.
Old Nov 2, 2015 | 12:20 PM
computerwi's Avatar
computerwi
I use Plexus for Nav screen,speedo/gauge plastic and wood trim and have for years.
http://www.autogeek.net/plexplasclea.html
If water is damaging the coating, then I would hesitate to any chemical whatsoever.
Old Nov 2, 2015 | 12:22 PM
computerwi's Avatar
computerwi
Based on the pattern of "peeling" experienced by both the OP and NXOwner, I doubt the cause is over spray. What are the chances the pattern would be a "curtain-like" band starting from the top? I would believe the overspray theory more if the damage pattern was in spots (like from a spray bottle).
Old Nov 2, 2015 | 12:39 PM
NXOwner's Avatar
NXOwner
My theory is that the car wash folks were spraying the windshield which caused some spray to get on the upper top portion of the screen. Maybe they noticed this and wiped across the top. I also had some bubbling on the bottom left side, too.
After my dealership replaced the display, they said that they "found moisture in it". In my case, I can think of no other way moisture got on/in it other than overspray. Where I live has typically low humidity. I have had no condensation whatsoever anywhere inside the vehicle. Remember, my NX was only three weeks old when this happened, so I can practically remember everything about the vehicle and the nav screen.
Old Nov 2, 2015 | 12:44 PM
Joeb427's Avatar
Joeb427
So it sounds like the damage had nothing to do with the outside screen.Fluid got in through the upper portion and got behind the screen.
I wouldn't think the NAV screen would be so easy to damage.
