NX - 1st Gen (2015-2021)
Beat-Sonic bypass
Old May 4, 2015 | 12:52 AM
statik808's Avatar
statik808
Default Beat-Sonic bypass
Anyone successfully installed a BB6223 on the NX? I would love access to certain features while "in motion"...
Old May 4, 2015 | 01:02 AM
mk7045's Avatar
mk7045
it works perfect
Old May 4, 2015 | 10:02 AM
BriSmi's Avatar
BriSmi
Will it play DVDs on the NAV screen?
Old May 4, 2015 | 11:41 PM
mk7045's Avatar
mk7045
dvd player is working while driving if you installed beat-sonic.
Old May 5, 2015 | 12:48 AM
statik808's Avatar
statik808
i don't have nav but want to be able to access everything while driving. Well, primarily the a/v input so i can mirror my mobile to use google maps or waze. has anyone posted a DIY to remove all the panels to access entertainment sys?
Old May 5, 2015 | 08:53 AM
legrunt's Avatar
legrunt
I've done mine. Used the Prestigious Society bypass.
I don't have the instructions anymore, but you just have to use common sense and look for all overlapping panels, and remove the outer panels first. Lets see if I can recall.
Start by opening the center armrest. Pull off the small plastic piece between the armrest and handrest. Then pull off the hand rest.
Pull open (no need to remove completely) the side panel inbetween the door and the glove compartment. Pull off the entire trim above the glove compartment
Pull open (no need to remove completely) the trim thats below the trim below the start button. Then pull off the trim below the start button.
Pull open till 90degrees the trim on the center console where you knee rests, then pull straight off. (both sides)
Carefully pull off the silver trim surrounding the centre console.
Pull the gear shift boot down off the ****. Unscrew the ****. Pull off the entire trim surrounding the gear ****.
Pull off the climate control panel.
If you have actually managed to get this far, you would have exposed two bolts that you can reach with a socket wrench on either side of the player. Undo those and then pull off the player. Now you have access to the rear of the player to install the bypass.
Reverse all the steps to put everything back together.
To be honest, I was totally amazed that ALL that removal and only two bolts were involved. EVERYTHING else was just pull off/snap on.
Old May 5, 2015 | 09:15 AM
BeatSonic's Avatar
BeatSonic
Former Sponsor
We have a step by step DIY that comes with the product. If you would like to see it beforehand, send me a pm with your email address and I'll send it over
Old May 11, 2015 | 03:59 PM
statik808's Avatar
statik808
went with the beat-sonic setup. i guess i could snap some pics if anyone is interested in the tear down.
Old May 12, 2015 | 07:31 AM
philwojo's Avatar
philwojo
Would love to see your pics and the process you used, please post when you have time.
Phil
Old Jun 2, 2015 | 04:38 AM
catchtanya's Avatar
catchtanya
Id love to see this too. Id like to be able to play DVD's on long trips for the kiddo in the center rear.
jkeifer3
IS F (2008-2014)
Mar 24, 2009 03:40 PM
DeviousOne
Jan 19, 2009 09:40 PM
lexusman23
Jan 30, 2007 09:59 PM
03LX470
Nov 5, 2006 06:59 AM
gbrowndsl
Nov 9, 2001 12:51 PM
