NX - 1st Gen (2015-2021)
DIY - Poor Door-Bottom Seal FIX
Old Apr 12, 2015 | 06:42 AM
  #31
corradoMR2's Avatar
corradoMR2
The pursuit of F
Originally Posted by legrunt
Running Boards solved the problem for me...
Great to hear. Can you post pics underneath to see how the boards are helping?
Old Apr 12, 2015 | 05:19 PM
  #32
legrunt's Avatar
legrunt
At the office now, running off to a meeting. Will try and catch some time later on during the day to see if I can sneak downstairs to catch a few pics...
Old Apr 12, 2015 | 09:27 PM
  #33
legrunt's Avatar
legrunt
I've attached two pictures... one showing the running boards with the doors open to show how much it covers the bottom, as well as one more from underneath, also showing the coverage.
Only one thing I'm not so happy with. When there's water on the road, the water thrown up by the tires makes an awful hollow scraping sound as it hits the undersides of the running boards. Well, this weekend, they are coming off again to get a few coats of rubberized undercoat.
Attached Thumbnails DIY - Poor Door-Bottom Seal FIX-rb-underside.jpg   DIY - Poor Door-Bottom Seal FIX-rb.jpg
Old Apr 12, 2015 | 10:51 PM
  #34
typocl's Avatar
typocl
glad you're able to confirm the noise from water hitting the running boards - are you going to use a rubberized spray, or a rubber roof style material? I was going to use the roof material at some point. But I have time...rainy season is almost over.
Old Apr 13, 2015 | 12:50 AM
  #35
legrunt's Avatar
legrunt
I plan to use a spray. If that doesn't work, then I'll get some dynamat or something...
Old Apr 13, 2015 | 07:06 PM
  #36
corradoMR2's Avatar
corradoMR2
The pursuit of F
Nice to see the boards cover the bottom of the doors. This definitely blocks any snow or dirt sticking to the doors. Thanks for the pics
Old Apr 21, 2015 | 05:51 PM
  #37
legrunt's Avatar
legrunt
DO NOT USE RUBBERIZED UNDERCOATING!!!!!
THAT STUFF IS A ****ING NIGHTMARE!!!!!
It sticks to what you don't want it to stick to and doesn't stick to what you want it to!
After it was dry, I noticed it rubbed off the smooth aluminium easily. But when the dry stuff got onto my fingers, I had to bloody scrub them almost raw! Doesn't freakkin make sense, I mean, its already DRY!!!
Also, I noticed the stuff wasn't doing much in terms of insulating the scraping hollow sound rainwater makes when its thrown up by the wheels...
So I used a power washer to scrub most of it off the boards. That was my second mistake. My legs were peppered with that stuff!!!!
I ended up using gap filling foam. I sprayed on a few lines and let it expand, then trimmed off the excess after it cured.
Old Apr 21, 2015 | 06:49 PM
  #38
typocl's Avatar
typocl
oh goodness, thanks for the sacrifice. I was thinking about foam as well, but wasn't sure how to level it. I'll do that on some weekend. I had realized that some rubberized roofing material would probably be a pain to apply because of the angles.
So is the foam working to cut down the noise of water hitting the bottom? Hope it lasts.
Old Apr 21, 2015 | 07:01 PM
  #39
legrunt's Avatar
legrunt
Just did that yesterday, and it's been dry here for a few days already...
I'll let you know the next time it's wet outside.
Old Apr 22, 2015 | 06:25 PM
  #40
legrunt's Avatar
legrunt
Ok, it rained cats dogs monkeys and donkeys last night just as I was leaving the office.
Verdict - the foam cuts out quite a lot of the grinding hollow sound from spray from the wheels, but it is still audible.
I would estimate 50-60% reduction in the noise level.
I'm still scrubbing my legs till today...
Almost all gone, but still a few spots...
Old Apr 22, 2015 | 06:36 PM
  #41
4482's Avatar
4482
I wonder if a storm door self adhesive strip would work on the door problem?
Old Apr 22, 2015 | 08:20 PM
  #42
corradoMR2's Avatar
corradoMR2
The pursuit of F
Could be worth a try, but I'd still staple it since the exposure to snow/water freeze/thaw could eventually un-glue it.
Old Aug 6, 2015 | 10:32 PM
  #43
N54TT's Avatar
N54TT
Do you think the mud guards help alleviate the build up of snow and dirt at all?
Old Aug 7, 2015 | 10:43 AM
  #44
typocl's Avatar
typocl
I think someone mentioned that the running boards helped with that. I don't recall any mention of mud guards helping.
Old Aug 7, 2015 | 12:59 PM
  #45
corradoMR2's Avatar
corradoMR2
The pursuit of F
I've had the mud guards on since delivery and the snow still built up. It's only after implementing this seal extension fix did the accumulation notably reduce. Also, as per typocl, one or two members have also pointed out a reduction of snow with the running boards. Would be interesting to know if anyone has done both.
