2018 - Is my engine knocking? (Video)
Hi all,
We have a 2018 NX300 AWD that we bought about 4 years ago certified with 12,000 miles. It had service records and we have kept up with oil changes as well. It only has 43,000 miles now. I was doing an oil change today and it just sounds a bit odd - almost like engine knocking. I know it makes ticking noise with the injectors and all that but to me sounds a little odd. No metal in filter or oil at all.
Is this normal noise for this engine?
Uploaded a video to YT below
Interesting. Something is. If it was a conventional engine I would say a loose flywheel or at the other end a slipping or loose pulley. Check oil level as it may also be oil slap if too much in sump.
Just did an oil change it’s only 5 quarts with a tiny bit more. (Lexus calls for 5.2 with filter) Level is below the top mark on dip stick. 0W-20 Synthetic
I have used a 3 ft long of clear vinyl tubing about 3/8 to 1/2 in diameter as a stethoscope before. Put 1 end to your ear and move the other end around the motor to try and hear where the sound is coming from. Just my 2 cents.
Yeah I'm gunna have to investigate more - just wanted to see if what I'm hearing is normal for this motor? Or is something off?
FWIW and on a separate note related to oil changes, I would check the oil level after the car has sat overnight and engine is cold to see where the level is on the dipstick. I recently changed my oil and put exactly 5 quarts and it still showed 1/4 inch over the F mark (I let it drain for 45 minutes before putting in new oil). This also happens on my other cars where I put less than the stated amount to get it right below the F mark.
This is my first Lexus and bought not too long ago, so still trying to find out the sweet spots.
qmanethan
LS - 5th Gen (2018-present)
Feb 10, 2026 08:44 AM
Landonrzr
GX - 2nd Gen (2010-2023)
19
Sep 29, 2021 08:21 AM
