Just bought a Lexus!!
Old Feb 3, 2013 | 08:17 AM
tjmhillz's Avatar
tjmhillz
Originally Posted by SlickGS4
So I just got a chance to look over the car and I noticed a few issues. If anyone is local (DMV) that can help tackle these three issues below let me know or PM me. I want to have this car ready in the next 2 months.
-Need to wire the aftermarket headlights for the car. Currently they do not come on when turned on. It is not the bulb as they came on when I wired them to the battery.
-Scanned the car and received code P0128. Not sure if this is attributed to it but when the heat is on, nothing comes out the front main vents, only the window and windshield vents blow air on.
-The car runs fine but I hear the belt after I turn on the car. Need someone to look over the car mechanically and tell me what needs to be done to prevent future problems.
Are you referring to the halos not coming on when you turn the lights on? Well since you tested them to the battery and they come on thats a good sign. Just find your parking lights and wire them into the parking lights. that way when you turn your lights on the halos will turn on. Or you can just wire them onto a separate switch. Ground one of the wires to a good ground source and the other straight to the battery and then you can control it by any switch that you choose.Wish i was closer i would be able to help you out.
Old Feb 3, 2013 | 11:51 AM
SlickGS4's Avatar
SlickGS4
Default Headlights
The headlights have loose wires everywhere. I believe the owner might have taken the ballast before he sold the vehicle. I will most likely have someone install HID's. I hopefully should have this problem resolved in the next two weeks.
Old Feb 10, 2013 | 09:27 PM
nate579's Avatar
nate579
I have to check it out. Some 19 or 20 Black staggered concave would look good.
Old Mar 26, 2013 | 10:45 PM
ecos's Avatar
ecos
hi noobie here - any techs /mechs out here, please PM me, I need some work done on my car.
Old Apr 1, 2013 | 05:24 PM
LexTech94's Avatar
LexTech94
PM sent to you ecos
RichS11
Build Threads
162
Jun 11, 2020 03:27 PM
SlickGS4
Jan 28, 2013 11:27 AM
DallasLex
Feb 15, 2008 08:57 PM
Tranman
Mar 1, 2003 10:20 AM
