No one has found the answer yet (cold start and pedal problem)
Old Oct 23, 2003 | 10:41 AM
SCfan's Avatar
SCfan
Default No one has found the answer yet (cold start and pedal problem)
I have read several posts so far about people having problems with their cars having a slight delay when starting up in the morning. Usually when you put the key and turn it the car will start. However, on their cars and now mine it takes a few seconds longer to start it as if it sputtering to start. The battery is fine, so we have no idea. Does someone out their have the answer???
Also once the car does start, when you press down on the accelerator pedal, it vibrates slightly. This is very annoying since I heard that these cars were supposed to shift better than most cars out their. Ihate getting the rundown from incompetent lexus techs and am hoping that someone has had a similar problem and gotten a satisfactory answer.
Thanks again, I am at the end of my rope on these ones!!!
James
Old Oct 25, 2003 | 01:05 AM
RSTSpeed's Avatar
RSTSpeed
Don't know about it taking longer to start, but does the car "knock" when you start it? If so, you probably have a main bearing wearing out. If not, I dunno what the deal with the pedal is...
Hope this helps a little bit.
Old Oct 25, 2003 | 09:51 AM
awj's Avatar
awj
Bluegr*** Performance
Eliminate your starter solenoid as the cause first. That is a common issue. That was the issue on my 93. If it starts rough, check your plugs,dist, button, wires and coil first. Air filter. Easy things first.
Old Oct 25, 2003 | 11:00 AM
SCfan's Avatar
SCfan
AWJ,
How do I find out if the starter solenoid ius the culprit? I will check out my plugs and the easy stuff as well. When I start my car in the morning I notice that when I give it a little gas it starts up easier.
RST,
What is the bearing you talk about? Is it difficult and/or expensive to fix?
Thanks for the help, hope to find the culprit soon
James
Old Oct 26, 2003 | 08:24 AM
RSTSpeed's Avatar
RSTSpeed
Originally posted by SCfan
RST,
James
The main bearing in the block/crank case. The "bearing" actually just as little piece of metal that sits between the crank and block or cap.... at least it is in a Chevy, lol. I would assume the same basic principles apply. Now that I re-read your first post ( ) , it's probably not that. I don't THINK you would notice it by touching the pedal, but jus notice it when it cranks (basically there's no oil circulating yet and the crank vibrates against the unlubricated bearing). It's a big problem if that is the case. If your car cranks and you don't hear or feel a vibrating or knocking, then you're probably good to go. Sorry to scare you, lol.
Old Oct 26, 2003 | 11:45 AM
mrshabo's Avatar
mrshabo
have you checked it with a timing light? i had the same starting problem as you and it fixed it.
Old Oct 27, 2003 | 07:23 AM
SCfan's Avatar
SCfan
mrshabo,
I am interested to hear about your fix. I have not checked it with a timing light. How would I go about doing that and what does it involve? Thanks and hopefully that will be my answer
James
Georgeonao
RX - 3rd Gen (2010-2015)
Nov 9, 2017 09:49 PM
calteg
IS F (2008-2014)
14
Feb 16, 2015 11:01 AM
Zinda
Jun 4, 2009 08:05 AM
SC30096
Oct 6, 2007 06:05 PM
SCfan
Oct 17, 2003 07:18 PM
