Squirting water
Old Dec 13, 2012 | 12:13 PM
apriledge's Avatar
apriledge
Default Squirting water
I have a 1990 ls 400 and it is squirting water from the right back of the engine. I can not see where it is coming from because it is blocked from my view. What water hose is it?
Old Dec 14, 2012 | 09:24 PM
mitsuguy's Avatar
mitsuguy
Maintenance Moderator
most likely it is a heater hose, but there are other things with coolant in them back there, IIRC... unfortunately, we would all be guessing as to the cause - one way to find out for sure - get it nice and warm while running and observe...
Old Jan 1, 2013 | 10:16 AM
Bluv's Avatar
Bluv
Is it water or coolant
Old Jan 1, 2013 | 03:03 PM
mitsuguy's Avatar
mitsuguy
being that it is squirting out, it must be coming from the coolant hoses, so its irrelevant whether it is water or coolant...
the only other thing in the area with water is condensate from the evaporator core when the a/c is on and in no way is it possible for it to squirt out... if it were to be plugged to the point where it doesn't drip freely, it won't build up pressure, instead it will soak the passenger floor board...
Cyrus701
Nov 28, 2018 10:35 AM
triage400
Jul 31, 2018 12:35 PM
Patsum
Jul 27, 2012 04:29 AM
bryanc182
Oct 14, 2011 02:38 PM
Inabj2
May 11, 2005 04:48 PM
