starting problems
Old Nov 19, 2012 | 02:23 PM
vlj73's Avatar
vlj73
Default starting problems
1997 ls 400 diagnosed at shop with bad starter now has new starter new battery new alternator all connections have been checked and cleaned,starter clicks when cold after it starts usually starts fine all day then clicks in the am sometimes starts fine 3 or 4 days then clicks will jump start immediatly even with 2 amp charger.......any ides????????????? this is getting old
Old Nov 19, 2012 | 02:30 PM
RTIS250's Avatar
RTIS250
Yes. I drove the LFA.
CL Folding 500,000
The parts that were installed on the car, were they factory Toyota parts, or aftermarket? Its not unheard of to get a bad starter, even though it is new. Also, it might be a good idea to check the cables that go to the battery terminals to make sure they arent corroded/separating. And check where the negative cable bolts up to, to make sure it has a good connection.
The initial thought i have when you explain the symptoms is a bad starter though...
cmmiller
GX - 1st Gen (2003-2009)
May 29, 2017 03:29 PM
darimura
23
Sep 27, 2012 12:52 PM
Kalogerus
Feb 4, 2012 02:05 PM
hoonami
Jun 9, 2009 12:31 AM
bridge4d
GS - 1st Gen (1993-1997)
Jun 6, 2006 02:33 PM
