I got this car used and was told coolant was leaking. I looked under the car and took a pic. Tell me what you think i should check or do? I was told bad water pump even if its not the water pump i thinkits time. I have a 1998 gs4 with over 255k miles on it.
Reason: pic
I would certainly lean towards a water pump as well. Might want to check the water neck above the water pump though, it can leak there and trickle down. If you do the water pump, that will get resealed at the same time.
you can't link to pictures on google documents... you need to get it on a photo sharing site, or even facebook and then link to it... photobucket is just one option and its pretty easy to use...
