Evap system problem - from mofoco
Old Nov 30, 2011 | 06:36 PM
mitsuguy's Avatar
mitsuguy
Maintenance Moderator
Default Evap system problem - from mofoco
Originally Posted by mofoco
Day before yesterday VSC light came on...
Check engine light is now on...Came on yesterday...Auto Zone tested...Got 3 different Troubleshooting codes...All 3 pertain to EVAP System...
PO441-Evap system incorrect purge flow...Probable causes...Block vapor canister, Vent solenoid malfunction,purge solenoid malfunction...
PO442-EVAP system small leak detected...Probable causes...Failed vent solenoid, Loose/missing fuel cap (NOT), purge solenoid malfunction,EVAP hose faulty.
PO 446-Faulty vent solenoid, Poor electrical connection, open or short circuit condition
All 3 codes include Vent Solenoid malfunction as probable cause...
Have not yet tried to reset VCS light...Thought I'd wait till I got the CEL problem fixed, hoping the VSC light would then go away...AUTO ZONE DOES NOT CARRY THE PART...I've checked on line but cannot locate a vent solenoid part...
What and where is this part located??? Clueless in Las Vegas...Bobby...
PS...My phone # is 702 328-8866...If you've got the time maybe you can call..
This part you are having issues with is generally located on or around the charcoal canister on almost all vehicles that I can think of... I would have thought AZ would carry that, but you might try Napa and O'Reillys... It is probably named something more along the lines of Vapor Solenoid Valve I would first locate it and check the electrical connections...
Please include the make, model and year of your car so that we can be of more help...
Lexy
GX - 1st Gen (2003-2009)
Jul 23, 2021 12:47 PM
is250fsprt
Sep 25, 2019 12:52 PM
Bocatrip
Sep 17, 2018 08:51 AM
andynoel78
Jan 16, 2016 04:24 PM
mofoco
Nov 29, 2011 10:53 AM
