ECU car will not start
Old May 4, 2011 | 07:51 PM
NSeagle78's Avatar
NSeagle78
Default ECU car will not start
My 1992 automatic SC400 will turn over strongly but will not start. I rebuild my ECU (replaced about 9 capacitors) and thought that had fixed the problem but after a day That proved not to be the fix. Help, any ideas?
Old May 5, 2011 | 07:42 AM
mitsuguy's Avatar
mitsuguy
Maintenance Moderator
fuel, spark and compression are the three things needed to make the engine start and run...
spark is easy enough to check - pull a plug or two and simply watch...
fuel - perhaps a little harder, but, still not too terribly hard, I just don't recall on the SC how to check - I'm sure someone on here has a write up - typically you can just pull the fuel return line to make sure there is pressure in the system, or there may be a fuel pressure port on the fuel rail itself...
compression - well, even with bad compression it should still stumble and at least fire a little... unless the timing belt has snapped or slipped, you should have enough compression to get further than you are...
start with spark, no spark - check coils, check to see if the coils are even getting triggered...
arfghan
GS - 1st Gen (1993-1997)
Mar 4, 2014 08:34 PM
1SICSC4
May 17, 2011 08:57 PM
baodalazi
Apr 6, 2011 09:37 AM
RAINBOW
22
Sep 21, 2010 07:57 AM
eagles22mh
May 11, 2010 08:55 AM
