automatic transmission fluid
for your transmission oil change, do you guys usually just go to lexus dealer to have it done, or you get the fluid yourself and have them changed outside? what brand and kind of oil is good for the gs400? i have 30k miles on my car and i have to change the transmission oil, so i wanna do it right
The dealer did mine but I bet any tranny shop could recommend some really good brands to use. Just make sure that it can be used in your tranny first (Japanese motors and tranny are alot more advance than American ones!)
Originally posted by rominl
for your transmission oil change, do you guys usually just go to lexus dealer to have it done.....
...or you get the fluid yourself and have them changed outside?
You mean transmission fluid change not " transmission oil change." :eek: :eek:
QUOTE
"for your transmission oil change, do you guys usually just go to lexus dealer to have it done, or you get the fluid yourself and have them changed outside? what brand and kind of oil is good for the gs400? i have 30k miles on my car and i have to change the transmission oil, so i wanna do it right"
Just busting your chops, we all know what you mean.
QUOTE
I hope lexus reads this.Everyone of my Mercedes has had a drain plug on the torque converter.The lexus do not.So all you could drain at home is about two Quarts.You have to take it to someone that has the equipment to get the fluid out of the torque converter.If they have the machine,even the village idiot can do the change,make sure you use the type 4 toyata fluid.
I know the village idiot! and he has this machine!!!
I had a hard time trying to explain to him why I didn't want to run Dexron through it...Finally in about 2 weeks on his day off he is going to help me setup the machine with 4 gallons of TYPE 4 to flush out the system!!! (the fluid alone cost me $110 )
...when you are finished, can I have the two gallons left over for my own flush?
By the way, for those of you that want to change the ATF yourself, here's a good discussion on what's involved:
http://www.glue.umd.edu/~singletn/web/pages/at1.html
