no heat!!
Old May 19, 2002 | 02:43 PM
snoz's Avatar
snoz
Default no heat!!
Today when i turn on the heater the fan does not come on! any reason for it?
Old May 19, 2002 | 03:18 PM
fasthuh's Avatar
fasthuh
Check your fuses.
Old May 23, 2002 | 07:50 AM
wwest's Avatar
wwest
Default blower
You are aware that the blower doesn't run in for heating in "auto" until the engine water jacket temperature reaches 130F? Or in cooling until the A/C evaporator is somewhat cooler than the surround?
Other than that the blower motor has two supply circuits, if you manually put it on highest speed a relay is used to bypass the electronics circuits. Otherwise it probably is a fuse but that would likely mean that the blower motor has stalled or failed in some manner.
LexXxtacy
Aug 13, 2019 02:27 PM
tyncobb
Feb 12, 2019 04:37 PM
Sideshowsa
RX - 1st Gen (1999-2003)
May 21, 2014 05:00 PM
Meyagi
Dec 21, 2011 10:40 PM
