sc300 ac problem
Old Aug 12, 2008 | 07:18 PM
FrictionSc's Avatar
FrictionSc
Default sc300 ac problem
Hello everyone. I am having a problem with my ac in my 94 sc300. Just a cuple of days ago it started to make a grinding sound when the ac is on. It sound like the compressor is dry and need some oil. It only happen when i step on gas for like 2-5 sec. then it gose away. Have anyone have this problem befor? Anything will help thanks
Old Aug 12, 2008 | 07:23 PM
mitsuguy's Avatar
mitsuguy
Maintenance Moderator
the compressor, if it needs oil, is already damaged beyond repair...
Old Aug 13, 2008 | 01:36 PM
FrictionSc's Avatar
FrictionSc
thank you for the info. I will replace the compressor.
Old Aug 18, 2008 | 09:38 AM
StiCk3's Avatar
StiCk3
sorry if im hacking a bit but my compressor is doing the same thing (grinding noise whenever on) so the compressor is done. Someone told me that i need to replace some other parts as well. What else do i need to complete the repair?
Old Aug 18, 2008 | 10:16 AM
lexluger71's Avatar
lexluger71
very ironic, after i did a code diagnostic , my compressor started grinding and a burnt smell appeared. is my compressor gone too., the clutch stop spinning, is there something else i can do, like just change the clutch.
Old Aug 18, 2008 | 06:34 PM
mitsuguy's Avatar
mitsuguy
receiver/drier needs to be replaced at a minimum, not a bad idea to replace the thermostatic expansion valve as well... then the whole system needs flushed, then evacuated and recharged...
if the clutch gets locked up and will not turn, then that means the a/c compressor is locked up as well... you can turn the a/c compressor by hand if it is working properly...
Old Aug 20, 2008 | 07:54 AM
lexluger71's Avatar
lexluger71
do you know if there is a write up on changing the compressor, i have searched all over the place. i priced out the parts in lexus, the compressor is 600 and change and the clutch was 300 and change.
Old Aug 21, 2008 | 05:59 AM
mitsuguy's Avatar
mitsuguy
A/C is one of those things that if you have to ask how, you probably shouldn't be doing it yourself...
with an A/C compressor, it's a good idea to go ahead and change the receiver/drier and the TXV... The complete system should be flushed with an A/C chemical, then the complete system should be reassembled and brought into vacuum for 30-60 minutes (depending on temperature outside), then charged with the exact amount of required refrigerant...
my bet is that you do not have, at minimum, a vacuum pump capable of pulling 25 inches of vacuum on the system, which is going to be required to do this right...
Web Stories
Explore the latest stories
batmbl
Jan 9, 2011 02:45 PM
TLcoats
Aug 2, 2010 01:30 PM
VJZ
SC400 / 300 Classifieds
May 22, 2008 02:42 PM
kathleenkmh
Aug 2, 2003 11:36 PM
