Fuel Injector Cleaner... Which is the best out there?
Just to make sure, it won't hurt anything by dumping Fuel Injector Cleaner in the tank will it? As in, it is a pro-active measure and you don't dump it in only when something is suspected to be wrong?
Just want to make sure before I dump it in
Super Moderator
When I lived in Mexico, I was pouring it on virtually every 3rd tankful given the quality of the gas there.
Thanks
It's a waste of money if you buy products that does not contain a good amount of PEA. Not all fuel injector cleaners will work. ALL cars have some sort of carbon build up regardless of what anyone says. Yes, those who use 'supposed' top-tier gas will have some too. The amount of additive such as 'techron" or equivalent in gasoline is in very low concentration. It is not uncommon for refineries to add maybe 1 quart of additive to a hundreds and hundreds of gallons of gasoline.
As pingu stated, Redline SI-1 has some of the highest PEA concentration available with Gumout Regane slightly behind it (however it does cost less). Chevron Techron use to contain a good amount, but whether it still contains it is unknown.
