Timing gear removal; tips to loosen?
Old Aug 9, 2006 | 09:36 PM
nokian's Avatar
nokian
Default Timing gear removal; tips to loosen?
New to the Lexus brand. Just got a 98 ES300 and has an oil leak. Tracked it down to the rear cam seal; so going to do a timing belt, idler pulleys, cam and crank seals job. I'm to the point of trying to remove the timing gear sprokets. I made up a holder out of angle iron with 2 3/8" bolts that stick into the recesses of the timing gear. I've used a breaker bar and the 17mm bolt does not want to loosen. Am I correct in assuming that it is a right hand thread?? Is there another trick to holding the cam without removing the cam cover and holding it that way. Is there a Locktite compound on the threads? Any help would be appreciated. Didn't want to pull the cam covers off because they are not leaking now and it seems like that would be a lot of torqe on the cam to hold it in the center by the flats. TIA
Greg
Old Aug 10, 2006 | 05:44 AM
lexusk8's Avatar
lexusk8
Welcome to CL!
This sounds to me like a hard technical maintenance question for the timing belt area in your car. We have a master certified Lexus technician who moderates the Maintenance sub-forum in CL, so I'm going to move your thread over there, and hopefully your question(s) will be answered promptly. You can also try to use the search engine in the Maintenance forum while you are waiting for an answer.
Old Aug 10, 2006 | 03:42 PM
VVT-i's Avatar
VVT-i
Welcome CL.
I rest the cam pulley holder against some hard surface to stop it from spinning and use a long breaker bar with both hands to loose it up. Yes it's a right handed thread,but it really tight.
zchen101
Aug 25, 2023 05:20 PM
SATXSC400
Performance
18
Aug 27, 2022 02:46 PM
Equalizir
Mar 26, 2017 11:31 AM
donteatbug
Maintenance
Oct 26, 2015 05:41 PM
davincity
Dec 28, 2013 01:09 AM
