60k sevice..
Old Jul 24, 2006 | 07:13 AM
tmf2004's Avatar
tmf2004
5% Club. Killing it!!!
Default 60k sevice..
I just spoke to Lexus of Palm beach and the girl quoted me 449.95 for the 60k service. From looking over the PDF format of the 60k service they really do alot.. IS it worth getting it done at lexus? I change my own oil, all the brakes have been changed with in this last year and the tranny service was done before i got the car.. Should i take it down there and let lexus do the service or have my mechanic here do it?
Thanks
Tony
Old Jul 24, 2006 | 12:29 PM
Tammy's Avatar
Tammy
A trusted local mechanic or a local Toyota dealer are also options
The fluids need to be replaced...
along with a few odds and ends...
This includes:
Brake fluid - new is clear and turns tan/brown/black with age
Coolant and distilled water -
Power steering - Dexron III
Oil and Filter
Differential fluid - GL-5
Transmission fluid
Replace cabin air filter - check the K&N engine filter
Chassis inspection of the driveline...CV boots in sound condiction
Inspect for exhaust damage or exhaust leaks, any hanger damage
Suspension inspection of all rubber bushings
Shock or strut checks, including bushings
Inspection of steering rack and it's components.
Audio inspection of the engine running valve train
Check the rubber on the engine mounts
Check tire wear and pressures, indicating any allignment problems
Inspect for uneven brake rotor wear
Check A/C and Heater operations
Old Jul 24, 2006 | 03:42 PM
tmf2004's Avatar
tmf2004
This includes:
Oil and Filter
Transmission fluid
thanks Tammy.. DO they do a complete tranny flush? or drain and fill?
Thanks
Tony
Old Jul 24, 2006 | 08:36 PM
Tammy's Avatar
Tammy
I would recommend a couple of drain and fills, five hundred miles apart.
zmoneyJD
Apr 10, 2017 02:07 PM
IStoSC
Apr 3, 2011 11:02 AM
ezzrider
25
Mar 13, 2011 07:15 PM
cm09578
Apr 3, 2008 09:35 AM
Richie3000
Maintenance
Aug 8, 2004 01:45 AM
