Torque Values
Old Apr 23, 2006 | 07:44 PM
dallg's Avatar
dallg
Default Torque Values
replacing gasket on oil pan ( 98 ES300 ), can someone tell me how much torque is needed to tighten?
Old Apr 23, 2006 | 07:51 PM
GSteg's Avatar
GSteg
5.75ft.lbs for 10mm bolt
14ft.lbs for 12mm bolt
There should bolts 17 bolts total.
Old Apr 24, 2006 | 05:09 AM
dallg's Avatar
dallg
Thanxz man, now all I gotta do is figure out how to drop the pan without messing it up..the owner before me RTV'd the damn thing..lol
Old Apr 24, 2006 | 07:03 AM
Pheonix's Avatar
Pheonix
Cool
RTV has 0 strength, it's a better seal than the stock gasket too.
Just use something to slit the RTV a little bit then wiggle the pan & it'll let go. If not, use something like a gasket scraper, or screwdriver to pry it up. Don't crazy, tool steel VS aluminum = marred aluminum.
Ultra Black RTV is great stuff. $5 tube, use that putting the pan back on. (Clean the surfaces with an alcohol based something, or acetone if it's impossibly oily.)
On the lower pan it's 10 bolts, 2 nuts
Oil strainer is 1 nut 2 bolts
Upper pan requires moving the y-pipe stay & flywheel housing cover 2 bolts
Then 17 bolts, 2 nuts
10mm 5.75 lb-ft
12mm 14 lb-ft
14mm 27lb-ft
Like he said.
VicSWFL
Apr 20, 2017 11:58 AM
volson
Oct 30, 2015 08:38 PM
LZO
Jan 28, 2013 12:41 PM
Renegade
Aug 7, 2011 01:32 AM
nicks88
Dec 13, 2010 07:19 PM
