Adding Freon
Old Apr 12, 2006 | 08:42 PM
GOLDSc300's Avatar
GOLDSc300
Default Adding Freon
Does anyone have a "how-to" on adding frion to a SC400. I'm not sure where the high and low pressure valves are located. Any help would be appreciated.
Old Apr 12, 2006 | 09:22 PM
neurocity's Avatar
neurocity
Not quite my tempo
Take it somewhere and pay the money to do it right!!!
I almost ruined my AC system in my VR4 trying to do it myself.
Its not that bad to get a re-charge...call your local "greaser" guys before a "chain" McService Center.
Old Apr 12, 2006 | 09:29 PM
SCoupe's Avatar
SCoupe
CL Folding 25,000
I'd second that advice. If your charge is low you've got other problems as well. Moisture is destructive. The AC system needs to be fully purged and recharged. I found a good speciality shop that specializes in Toyota that will do this for $139. That's a good price considering the cost of the coolant. I don't think its Freon in these, btw.
This work is probably not worth do it yourself.
Old Apr 12, 2006 | 09:30 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
Psssssst ....... "FrEon"
Old Apr 13, 2006 | 12:32 AM
PERRYinLA's Avatar
PERRYinLA
Haha.......now now, Brian- if you start correcting everyone's spelling on the forums, you'll never finish!
Old Apr 13, 2006 | 10:40 AM
T0ked's Avatar
T0ked
I believe it was good old freon in all SCs before 1995. I know mine, 1993 SC, is the ozone destroying freon type.
Old Apr 13, 2006 | 11:43 AM
damon's Avatar
damon
Not only is there a color code system to keep people from screwing this up but the inlets are threaded differently. In other words you have to really "out Darwin" yourself to mix the 2 refrigerants up. BTW its R-12 (freon) and R-134A
Old Apr 13, 2006 | 12:50 PM
SinisterSC's Avatar
SinisterSC
Any service center should be able to to a Leack check and re-charge for less than $120. Me personally managing a multi-million dollar service center actually talk my customers into converting over to R134A. R12 isn't as readily available as it used to be and I don't even think it's really manufactured anymore. You can buy a conversion kit from places like PepBoys and Advanced Auto Parts. Fairly a simple process. But get the system checked for leaks first before you go any further.
Old Apr 14, 2006 | 07:14 AM
swfla's Avatar
swfla
If your system has the old style freon, by law, a shop cannot recharge your system without repairing the cause of the leak first (or upgrading the system to R-134). You also cannot purchase this type freon yourself. Point is, be prepared for a repair bill if it's the old style. With the new style system, you can buy and recharge yourself but it's still good advice to have a pro evacuate, dry and recharge your system.
You are not compelled by law to repair the new system...Let us know how it went.
Old Apr 14, 2006 | 01:25 PM
nthach's Avatar
nthach
Leave it to the pros. R-12 needs a EPA/MACS cert to purchase and service. DIY R134a has stuff you don't want in your system.
Old Apr 16, 2006 | 11:37 AM
trukn1's Avatar
trukn1
NELOC Mod
Sinister, am I reading this right???? You manage a service center??. Am looking for a good quality place to have my 92 LS serviced and worked on. Where are you in MD? LIve in Baltimore. PM me so we can talk further.
Old Apr 17, 2006 | 08:15 PM
SCoupe's Avatar
SCoupe
CL Folding 25,000
Any service center should be able to to a Leack check and re-charge for less than $120...
The Bay Area in Northern California could use a little price competition. $139 was the best I could find form a place that I could trust. Anyone this way done better?
Old Apr 20, 2006 | 03:21 PM
simoncpj's Avatar
simoncpj
Default just did this
OK, this is very easy.
First, AC Compressor on drivers side, near lower front of engine block. It has two hoses going into it. On the front of it is a valve. It has a small schraeder valve stem inside it (like a bicycle tire). Hit that to see if there is positive pressure.
On the top of where you would think of the radiator is, drivers side, is another valve fitting. This is the high pressure side (you don't really need to do anything here).
If the system is still R12, there will be screw on fittings on both. If R134a then they will be quick connect fittings.
If there is little or no pressure and you want to give it a whack yourself, go to the auto parts store and get two kits. First a leak test kit (it will have UV dye, an ultraviolet penlight and yellow glasses and leak sealant). Second, an R134a conversion kit. This will have fittings to change from screw to quick connect, freon (with oil mixed in) and a fill gauge. Also get a valve stem tool and some new valve stems.
If there is R12 left (any appreciable amount) you need to get the system evacuated. They convert it with the fittings and change the valve stems. You should get it vacuumed, but I had a little pressure left, so didn't. Then follow the directions on the kits.
Old Apr 20, 2006 | 03:35 PM
VVT-i's Avatar
VVT-i
Please take it to the shop and get a proper diagnosic. Those freon need to be recycle and not allow to dissipate into the ozone, both R-12 and R-134.
Old Apr 20, 2006 | 06:33 PM
techsc400's Avatar
techsc400
Default Periodic Check up for the AC system
This thread made me wonder if periodic maintenance is needed for the AC system or not.
My 95 SC4 has 90K miles on it. AC blows really cold air and works very well.
But I am wondering that I should do some maintenance work or not to prevent future problem. So far, I haven’t done anything for the AC system.
We all know very well about scheduled maintenance such as timing belt, water pump, etc.
How about AC system?
