Automatic Transmission Fluid type
Old Nov 19, 2004 | 01:47 AM
Lexusfreak's Avatar
Lexusfreak
Double check both with a couple of dealers & your owners manual bean......your generation ES is the same as mine (I have an 01) & require the Toyota type IV, but I know they made many enhancements between those years (including the powertrain) so I can't say for sure if you need it or not.
Old Nov 19, 2004 | 05:26 AM
Vic Nyce's Avatar
Vic Nyce
Post
ok thanks guys. for the dex III is there a preferred brand?. my car did not come with the manual . and i did not want to create multiple posts on a covered topic. so...back from the dead
according to lexusk8 over here
https://www.clublexus.com/forums/sho...5&pagenumber=2
i need +/- 4 qts of Type-IV.....man if i had hair i'd be pulling it outta my head the dipstick doesnt specify what kind of ATF and the car didnt come with a manual.
Old Nov 19, 2004 | 02:45 PM
VVT-i's Avatar
VVT-i
The ES used Dextron III from 1990-1998. They switch to Type-T in 1999 along with the new VVT-i engine. The easiest way to tell what type of ATF is by check on the dip stick or if your ES got the new VVT-i engine then it will take Type-T.
Old Nov 19, 2004 | 03:08 PM
VVT-i's Avatar
VVT-i
I just found one of my tranning book back in 1998 when I had to go to the new model class. I don't know you will be able read it or not, because I have to scan it and then resized the image so I can post on CL.
The 97-98 ES used the A541E transmission which is used Dextron III. The 99-2003 used the U140E(same as on the RX300 2WD) which is used Type-T. They used the new 5 speed transmission in 04, but still used Type-T.
In Vic's car he owned a 1997 ES, so he need to stay with Dextron III. I hope this will clear up a lot of confusion about this topic.
Old Nov 20, 2004 | 06:28 AM
Vic Nyce's Avatar
Vic Nyce
SOLID much thanks for the scan. cant argue with black and white.
update. i did the first "phase" if you will of the drain and refill routine this morning. she took almost 3 quarts of Dex III and cost me $34 bucks.. the guy who did it couldnt understand why i didnt just do the flush. i wanted to reply back what i read here but i didnt want to mix it up and sound like i made it up. anyway. the trans feels better already. i will go back next week and do a drain and refill again. i should keep doing this until it drains red right?
Xjvstn
Mar 31, 2025 07:33 PM
mmatheny
Oct 19, 2009 12:17 PM
Carbon J
Maintenance
Dec 16, 2003 08:49 AM
Japanimal
Jul 24, 2003 07:22 PM
